Question about Canon imageRUNNER 5000 Copier
Canon imagerunner 5020
The paperjam report displays and there is no paper inside....how can we reset
  • Anonymous Nov 12, 2007
    Hi, I have Canon iR5020 but a didn't communication with my server in manager Active Diretory. How I do this communication??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
You have either a bad sensor or there is a small piece of paper on a sensor.
1-take out all trays ( or open and look from both sides ) look at where the paper feeds ( where the tires are) there is a small black lever if lifted will snap back in place, spring loaded. is there paper there?
next open copier put handle down, will bring transport with belts down, look to the right there are two long rollers and another sensor there or on the transport itself does it have paper or spring action?
next open left side where it gets hot ( good idea to do this one when cold) there is a sensor there usually on the door itself, next if you have a duplexer open and check the top and bottom of duplexer
next check sorter
if there is no paper anywhere bad sensor.
Posted on Nov 16, 2007
Need to install ir 5020 onto server. Do I need any config software first like HP JetDirect?
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
Sep 13, 2011 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 5020 Copier not printing parallel attached
open your cd and try PrinterDriver Installer from misc folder
Apr 06, 2010 | Canon imageRUNNER 5020 Copier
Imagerunner 5020 scan to email
It can't identify the link and I suspect you've either had someone modify your server with new software updates, or there has been some network maintenance done that has moved, altered or deleted the server link. It doesn't seem to be a problem with the IR5020 if your other IO activity is unaffected.
Aug 28, 2009 | Canon imageRUNNER 5020 Copier
Canon ImageRunner 2270 copier - how can I change the paper select
There is a blue papersize sellector in the paper cassette with an arrow on it,just move that sellector untill the 11/17 mark.change the paper stops inside the tray to the correct possition and the machine will display the correct paper size option.
Jun 18, 2009 | Canon imageRUNNER 2270 Copier
Letter Drawer 1 on Model IR5020
look behind tray for paper preventing the feed rollers from knowing there is paper there
Feb 18, 2009 | Canon imageRUNNER 5020 Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any...
check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Feb 09, 2009 | Canon ImageRUNNER 330s Copier
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 5000 Copier Logo
94 people viewed this question
old marine
old marine
