Question about BenQ FP567s 15" LCD Monitor
I have a westinghouse LCD screen that keeps blanking out
The LCD screen doesn't display my laptops screen . I have tried using the  " function 4" buttons on my laptop which sends the signal of the laptop picture to my LCD and nothing. I don't know what else to do?
Backlight working but Display still blank, what could it be?
If you connect an external monitor to the video port on your laptop, power up the monitor first and then boor up the laptop and the video information will automatically display on the external monitor. This will indicate the on-board video is functioning OK and the problem is the video connection to the LCD screen.
The video connector from the LCD screen may need reconnecting to the motherboard to restore video information on the LCD screen.
Sep 09, 2012 | Sony VGN-CR220E/L Notebook
Laptop screen is black
There are a couple of reasons that a laptop screen could blank our. The first is that many laptops have the ability to output video to an external monitor or projector, such as for video presentations. In order to save battery life, there is a function key combination that can be used to blank the laptop screen. Most laptops have these "functions" on the F1-F12 keys in blue and there is an "fn" key that must be used with them to activate the function. Look for a key that has a blue "square" with vertical lines on either side of it. This is the Monitor function key. Press and hole the "fn" key, then press the Monitor function key. See if the screen returns. A corrupted video driver could also be the problem. Do you have any display when booting up? If so, try using the F8 key to get to SAFE Mode. If you have a display there, check and see if there are any problems with the video driver, or just reload the driver. The third possibility is the the LCD's backlighting source may have failed. IF this is the case, you probably have an older laptop and replacement is usually cheaper and more cost effective than repair.
Jan 09, 2012 | Acer Computers & Internet
Lights come on, but blank screen
Hi estees823,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 20, 2011 | HP Pavilion dv9000z Notebook
My Aspire 6920g has the screen completely blank and I can hear it work. What is going on? Any ideas?
Hi ribeiroal,
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
Hope this helps.
Jun 03, 2011 | Acer Aspire 6920-6422 Notebook
Laptop display goes blank after a second, not lcd inverter
I have had a similar issue with an LCD monitor and the issue was not with the inverter itself but the backlights. They can go bad and short (which is where my issue was. Once they were removed the screen was working again (the lights needed replaced).
Hope this helps!
Nov 08, 2009 | HP Pavilion tx2500z Notebook
Baterry went off. i have charged it but the screen wont come on though i hear the fan. i have to remove the battrey to put it off. have tried an external monitor and it says computer on sleep mode. press...
Perhaps a result of the auto display off. press any key to activate the screen again.
If using the LCD screen, make sure the priority is not set on an external monitor. To do this, press the Fn function key combination to set the display priority.
if you use an external monitor:
1. Check whether the monitor is switched on
2. Check if the power cable is properly connected
3. Check if the cable menguhungkan external monitor and the notebook is connected correctly.
4. Try to set the constrast and brightness on the external monitor
Nov 01, 2009 | Toshiba Satellite A355D-S6921 Laptops
Blank LCD laptop does turn on
I beleave you may need to press the function key as well as the F-4 key to bring up an external monitor.
Try holding down the Function key and tapping the F-4 key while watching the screen on the external monitor.
Is your unit within warranty, HP offer an extended 1 year on top of your normal 1 year warranty for video and motherboard issues.
Hope this has helped.
Sep 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Dell Inspiron 1501
If the laptop keeps working, and you can use it on an external screen, then it is likely an hardware fault.
First perform a complete system recovery, like probably already instructed by the Dell support helpdesk. This will practically exclude the possibility of a driver or system problem.
If the problem is hardware , then you may have a faulty inverter board , a bad LCD display/LCD ribbon connection, or a faulty video adapter (integrated with motherboard).
If the problem is the inverter, then the screen will go dark, and the laptop will keep working on external display. This is probably your case.
If the problem is LCD display or ribbon cable, then the display will be blank with light on , and the laptop will keep working on external monitor.
Fault concerning video adapter usually cause the the system not to work at all, and it is uncommon under conditions described.
Sep 04, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
BenQ FP567s 15" LCD Monitor Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
