Question about Sony KP-57WS500 57" Rear Projection Television
No picture it clicks on then clicks off ....red inicator light in front blinks several times
  • chuchito24 Oct 25, 2007
     the clicking comes from back lower left corner(rear view)
    no help so farr
    Genius:
  • 1,694 Answers
Fuse is OK = you have click & blinking light.
There is no lamp = this model is rear projection with RGB tubes.
   1)check soldered-in pico fuses in power supply-if you find a
      bad one(open) then...
    2)Look for shorted C514 near flyback transformer
       102K / 3KV  Sony part # 1-161-754-00
     additional troubleshooting in power supply may be needed..T.
Posted on Oct 26, 2007
Have you check the fuse in line with the power supply? Or it is possible that your lamp is blown. That is what happened to mine.
Posted on Oct 25, 2007
What does the red blinking boat light inicator with waves mean??
Check the coolant level in the radiator and not the reservoir for starters. It would be explained in a owners hand book. have a service technician check it out.
Oct 01, 2013 | 1999 Volkswagen Cabrio
Inicator light on one side always on
On front or rear? On the front, they are both supposed to be on anytime the lights are on, and blink only when the flasher is used. They are dual filament, so if only one is on at all times, replace the other as it is partially dead.
If on the rear, have you recently replaced any of the other bulbs? Check to make sure all bulbs are the correct part numbers. Having one wrong bulb type will cause some crazy problems.
Mar 15, 2012 | 1997 Volkswagen Passat
Power light went to red and no picture
when the light turns red press the Menu and the Device Buttons on the front panel both in together and hold for 6 seconds and then count the two didgit blinking light which will repeat a two digit blink code several times. Let me know the code and I will assist you
Jul 24, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
RED STAND/BY LIGHT WILL COME ON BLINK SEVERAL TIMES, HEAR A CLICK SOUND A FEW TIMES BUT TV WILL NOT COME ON,
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Sony Televison & Video
When I go to turn the PS3 on, the light goes on but then it goes back to a blinking red light and beeps and just repeats this process.
The blinking red light on PS3 is known to occur when something as simple as a misplaced connection occurs. It could also mean that the PS3's hard drive is malfunctioning or not functioning at all. You can take the following steps to identify and perhaps correct the problem. Check to ensure that all cables are properly and securely connected. If this doesn't solve the problem, try reinstalling the hard drive as indicated below.
Physically remove the hard drive from the PS3 console. Dust off the connectors, and gently and carefully replace it into the PS3. Very often this simple removal and replacement will fix the blinking red light problem. It may be necessary to remove and replace the hard drive several times.
If this does not work the blinking red light can only be inicative of a chronic overheating problem and will nead to be sent to sony for repairs.
Hope this helps
Feb 28, 2011 | Video Game Consoles & Games
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Sony trinitron KV-27S42
Replace the horizontal output transistor (Q502) and check the electrolytic caps in the vicinty, unsing an ESR meter. PLEASE NOTE THAT THE TV TUBE MIGHT BE CHARGE WITH ABOUT 27,000 VOLTS.
Sep 13, 2008 | Televison & Video
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
Sony KP-57WS500 57" Rear Projection Television Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
