Question about Lands Phones
Nortel M7310 I have a Nortel M7310 with Caller ID, is there any way to scroll through and look at the most recent incoming calls?
  • 201 Answers
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Posted on Oct 26, 2007
Yes you can  turn on Call log on your system,specifically if you have caller ID LS/DS trunk cards.
System need to have Call log turn on, providing you have CID trunk card then this should work
  • Elli Brown Oct 26, 2007
Next time you have an incoming call:
-Leave the handset down (do not answer the call).
-Press the 'transfer' button to scroll through the different displays until the caller ID is shown.
-Lift the handset to answer the call.
-The next time you have an incoming call it should show the caller ID.
Nov 15, 2016 | Panasonic KX-T7630 Corded Phone
Why doesn't one phone in my norstar meridian m7310 phones is not displaying caller id
Either COPY the config settings from a set where it works to those that don't, or on the sets that do not:
F**CONFIG, Terminals&Sets, (enter ext #), ... Telco Features, 1st Display Name: change between Name, Number, or Line.
And remember that some callers (esp Cellphones) do not provide Name info, so if the incoming calls at that extension are mostly from the same #s, it might be normal.
Aug 11, 2014 | NorStar Meridian M7310 Phone
Incoming caller ID on a Option 11 Meridian - can you recieve the incoming caller ID?
I believe so. You will need to know the construction of the caller ID string sent by the telco through PRI and then the ICS needs to be programmed to display the portion(s) of the string desired by the customer.
Dec 19, 2012 | Nortel Meridian Option 11 PRI/T1, NTAK09...
M7310 + Caller ID
You need CID service from teoco, Caller ID capable circuit packs in your Norstar system and 2 parameters turned on in programming under "terminals a & sets" for each extension. Also the CID will only auto display on sets that have the ringing turned on for that line. (you can also program a display button..feature-811). I doubt it is the software version but to display it go into programming and step down through the menu from 'Terminals&Sets' 10 items to 'Maintenance' and press 'show' then show again at 'System Version' this will give you a display like "SP: 30DHC04 NAT". Hope this helps. Bill C. We also do remote programming on Nortel CICS and MICS so equipped
Mar 15, 2010 | NorStar M7310 Corded Phone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Can somebody help me in setting up caller ID on my Nortel Norstar M7310
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
that should do it providing you have caller id service though your local telco provider.
Mar 26, 2009 | NorStar Meridian M7310 Phone
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Jan 08, 2009 | NorStar M7310 Corded Phone
Caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Sep 18, 2008 | NorStar Meridian M7310 Phone
Nortel norstar m7310 phone caller id problems
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
1,893 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
