The tv automatically by itself, without being touched at all, turns the volume down constantly, and even if you turn it up, it will go down whilst being increased. It has been doing this for 5 days, when I go into menu, it flicks from 1 to another, and will not allow a selection. It has deleted all DTV info though
SOURCE: dtv
I followed your suggestion and it works! You certainly do push the
info
menu
mute
power buttons but I cannot remember the exact order.
I may have pressed them altogether, or in a quick sequence and it may have been in standby mode or switched on.
Fiddle with it, because it does work.
What will happen is that you will get a set of commands on the screen. Use the remote to get to RESET. At first I coudn't get this to work as I kept pressing the "enter" button in an attempt to select this option, but actually you just need to press the right arrow button to select it.
Reset comes into place. Wait a while and press a channel number, then just re-tune. You will have to re-tune anologue and digital. This works - please share with others. Eamonn
SOURCE: Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
SOURCE: OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Len
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
