Question about Fujitsu Siemens SCALEO C772 17" CRT Monitor
What are the standard settings for the monitor, contrast, brightness etc
Someone adjusted the settings on my monitor now i only get a dark screen
0 characters
1 Points
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Feb 07, 2013 | Computer Monitors
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
Monitor screen too dark. Some things aren't even visible
Adjust your monitor Brightness and Contrast and make sure you set it high enough to be able to view text and images. Refer to the monitor manual.
Nov 15, 2009 | Likom Futura LD7 17" CRT Monitor
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Jan 14, 2008 | Computer Monitors
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Fujitsu Siemens SCALEO C772 17" CRT Monitor Logo
37 people viewed this question
Top Fujitsu Computer Monitors Experts
sonic boom...
sonic boom...
Owen Barnes
Are you a Fujitsu Computer Monitor Expert? Answer questions, earn points and help others
