Question about Dell Inspiron 1525 Laptop
Dell inspiron 1525 won't turn on
My mom has a Dell Inspiron 1525, and it won't turn on at all. I know that it's not the power cord because I've tried a different one that is compatible with her Inspiron and still nothing. Thanks for any help you can give me.
I have a Dell Inspiron 1525 and it won't power up. I do not know what the power jack is. There is a green light on the power box. Nor do I know what board you are referring to. Please advise. Thanks!
Posted on Jan 22, 2010
  • 674 Answers
Check the dc power jack connector, open the board. but if under warranty don't open it, bring to warranty..
Posted on Jun 05, 2009
SOURCE:
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Battery light blinking orange once, then green twice
LOL, It means whoever sold you that Power Cord probably sold you one with the interchangeable end that can plug into any laptop. If it's not the interchangeable end type, they sold you one that is not compatible with your laptop. Get rid of it in a hurry before it burn out your motherboard. You my friend need to get on ebay and purchase a power cord designed specifically just for an Dell Inspiron 1525. All you need to search for on ebay is Dell Inspiron 1525 AC Adapter. They probably cost less than $10
Mar 21, 2012 | Dell Inspiron 1525 Notebook
My inspiron 1525 won't boot, the scroll light and caps lock blink
Remove 1 stick of ram and turn on, if no! take out the second one and put back the first, and power on, if okay you know the 1 stick is bad. Remove main battery and power on, "long shot" if no change chances are it is a motherboard issue.
Mar 10, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 not turning on
hi. I suspect that you have either a dead battery or just need a reset. unplug the power cord and then remove the battery. wait two minutes and reinstall the battery.
this will reset everything. now try turning it on. if it won't come on plug in the power cord and charge the battery for 30 minutes before attempting to power up.
Jun 29, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Laptop Logo
2,807 people viewed this question
Clive
Clive
Alun Cox
