Question about Sony XL-5100 Projector Lamp for Grand WEGA SXRD KDS-R50XBR1, KDS-R60XBR1
Condensation water build up inside
Our picture is dark, the lamp has condensation in it
What is causing condensation on the back wall of my Electrolux dishwasher.
Thank you for your post, friend!
I see that you have condensation building up on the back wall of your Electrolux dishwasher. Condensation can build up due to water and cold air. You may have a leak inside of your gasket. I would recommend checking your gaskets to make sure they are not damaged. If your gaskets appear in good condition it could be an issue with your thermostat or element. I hope this information is helpful. -Matt
Feb 21, 2015 | Electrolux Dishwashers
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
I own a 50PL9126D/37 50 in DLP TV I bought used and the picture is dark so I took it apart because I was told it could be dusty or could be the lamp. After I cleaned the inside screen VERY carefully with a...
Dlp tvs have dark pictures,first thing u must be alway change the tv projection lamp.Specially,if u bought used,because u don't know how long the projection lamp been inside that tv already.After u change the projection lamp,still have problems or hear alots of clickings sound too.This problems the board call the Ballast board is it dead too.This Ballast board only job are just to ignite the tv projection lamp only.
Jun 08, 2011 | Philips 50PL9126D/37B 50" DLP TV
Have a jvc projection tv picture is to dark how can i correct this
How long is ur tv projection lamp been inside this tv.If the tv projection lamp been inside the tv like 1 1/2 or 2 years and watches tv everyday like 4 or 5 hours daily.The tv projection lamp life are ending.Replacement of the tv projection lamp,will solved this problems.
Dec 28, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
3-door undercounter refrigertor worktop surface
the coils that deliver the cold air are building up condensation. anything that gets cold in the outside should be insulated so as to reduce condensation. hope this helps
Sep 15, 2009 | Everest Refrigeration Freezers
The picture shows dark
Hi there
Take out the Projector's lamp and check for any black marks ( almost looks like veins ) on the inside of the bulb.
If you spot anything on the lamp , your lamp will need replacement.
If you can't see anything - then you might be in for a new Mainboard.
Very expensive exercise !
Mar 11, 2008 | NEC VT47 Multimedia Projector
Image Problem
either dust build up beyond lamp or discolouration due to condensation on inside of lens.take lamp out blow inside or use hairdryer ,replace lamp.
Feb 21, 2008 | Sony VPL PX31 Multimedia Projector
Sony XL-5100 Projector Lamp for Grand WEGA SXRD KDS-R50XBR1, KDS-R60XBR1 Logo
18 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
Paul
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
