Its not frosted up, but its running constantly and the freezer is hot inside and so is the fridge side
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
SOURCE: Maytag side by side fridge.
My Maytag side by side #MSD2957AE center front between the doors got very very hot. Too hot to touch. Also the top outside of unit and cabinet above unit unusually hot. I was worried and wondered if it could start a fire. I pulled out from wall and found lots of dust naturally. But the fan was not spinning. I moved it with my finger and it took off spinning. Unplugged, vacumed dust as best I could. Replugged and the fan started spinning on it's own. I plan to watch it. Also clean around the fan motor better, even pull it and lube it with some silicone spray. After running for a while center post is warm but not hot. thank you. JOE.
SOURCE: Freezer frosted Inside, Fridge not cool
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s please don't forget to rate my solution....Mike
Testimonial: "excellent thanks for the tips"
SOURCE: frost in freezer fridge warm
There are instructions available for the repair and replacement of the circulating fan that causes the refrigerator portion to get warm. The are available at www.AnyoneCanFixIt.com , and more specifically at:
www.anyonecanfixit.com/household.htm
