Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
Can't adjust TV from 1/200
The TV setting is stuck on 1/200. When I select any other setting, it will instantly appear back on 1/200. I need the setting on 1/1000. I tried clearing all camera settings, I changed it to what I needed using the RemoteCapture and it reverted to 1/200 after disconnecting.
Maximum flash sync at 1/200 sec
take the flash out and you should be able to go beyond yet. It is in the manual regarding TV
Have Fun - KD
Posted on May 06, 2008
Set closed caption options
It is done with the remote in the set menu, select closed captions and adjust to what you want, CC1 is most common for the feature but sets will in some cases have auto which if selected when sound is muted the captions come up instantly.
Dec 22, 2012 | Panasonic PV-DM2792 Triple Play 27 in....
Can't get the Aging Patterns to Stop
Go to the diagnostic menu and save.
Try also unplugging the TV for some time, to reset it , in case is stuck with the diagnostic menu.
Oct 27, 2008 | Samsung HLP6163W 61" Rear Projection...
Why does my MAG Innovision MA-32EF1ASP Flat Screen TV not function properly?
Have your hand ready when you turn the set on and instantly change the input to get back to the tuner in the set--some sets will shut down if hooked to a input with nothing connected.
Also if using a box connected to that input unplug box and set--wait and plug both back up to allow them to reboot.
Let me know what you find--not likely a reset will cure this but possible.
Apr 03, 2012 | Televison & Video
Top end rebuilt 1k ago. engine bored 70 over. Since rebuild about every 300 miles push rods tighten themselves up on back jug and have to be readjusted. solid rods. Any ideas what would cause this?...
You may still have gaskets trying to compress on the engine and if you had the valves and seats ground, they may be still seating in at that mileage. As the valves and seats wear, the valve stem raises up reducing the lash. All Ironhead Sportsters have solid tappets and should be adjusted to zero backlash. It's always best to set the tappets on these engine a bit loose rather than a bit tight. Always adjust the valves (tappets) with the engine absolutely cold. Keep in mind that the valve lash is set at zero with the engine cold. As the engine heats up, the cylinders and heads "grow" upwards introducing lash into the valve train. When it cools and contracts, it again should go back to zero lash but not hold the valves open. Make sure you get the locknut tightened properly.
Good Luck
Aug 25, 2011 | 1979 Harley Davidson XLH 1000 Sportster
Hi! I am trying to connect my Wii to the internet in order to watch Netflix on my tv
Connecting to wireless network
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Now, select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection 1: None"
5.Click on "Wireless Connection" and then "Search for an Access Point."
6.Select "OK" and the Wii will display all the wireless networks it finds.
7.Select the wireless network that is yours.
8.Select "OK," "Save Settings," and then "Yes."
Download Netlix
1.Select the Wii Shop Channel on the Wii Menu.
2.A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account. 3.If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right. 4.If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
5.Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
6.Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
After Netflix Instant Streaming for Wii has been added, the next thing you'll need to do is connect your Wii console with your Netflix account.
Connect your Wii console to your Netflix account
  1. On your Wii
    If you're not already on this screen on your television, select Netflix Instant Streaming for Wii from the Wii menu. (Don't have this option?) On this screen you will be presented with a code; remain on this screen during the activation process.
  2. On your home computer
    Using an online device other than your Wii console - such as a PC, Mac, or Web-enabled phone - go to (You will need to log into your Netflix account if you're not already logged in.)
  3. Still on your home computer
    Enter the code displayed on your television into the box on the bottom Netflix Web page, then click "Activate Now." (The code is case sensitive.)
  4. Back to your Wii
    Netflix will now attempt to activate the connection to your Wii console. This may take several minutes. When the process is complete, the Wii will automatically display your queue. (The screen on your computer will not change. Wait for the screen displayed by the Wii on your TV to indicate the activation has finished before going to another Web page.)
  5. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu.
Jul 11, 2011 | Computers & Internet
Tv wont go to hdmi1 and is stuck on dvd.
I think what is happening with your tv is it does not see the signal. If there is no signal going to the tv it will not let you select the source you like, in this instant HDMI 1. What you probably need to go do is look at you dishtv set top box and go to that box's menu and enable hdmi output. Hope this helps.
Mar 08, 2010 | Logitech Harmony One Advanced Universal...
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
# To return to the main menu, press and hold
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
Sep 26, 2009 | Pioneer DEH-2100 CD Player
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
42 people viewed this question
Top Canon Photography Experts
old marine
old marine
Are you a Canon Photography Expert? Answer questions, earn points and help others
