Question about Acer TravelMate 2300 Notebook
Shadded portion on screen
Am having a situation where the left section of my screen is darkenned or shaded. from bios screen to windows plzplzplz i need a solution my display adapters are working correctly.
  • 1 more comment
  • Anonymous Dec 22, 2007
    travelmate 8100 same issue. left portion of the screen appears darker. I have noticed that I thought the overall screen was not as bright as it once was. Laptop is 2 yrs. old.
  • amach Dec 24, 2007
    when i connected my external hard disk to acer travelmate2300 i had a pb of crash (blue dislay ),therfore i reboot my computer but after no display evn for bios startup
  • rachid77 Dec 26, 2007
    thank you for your suggestions about my pb of laptop travelmate 2300 ,i have no display (dark screen) when the startup even if the fairs and the hard disk motor still working without any bip
    confirmed that the problem is not due to battery
  • 117 Answers
I think this is panel or inverter probelm
Posted on Oct 26, 2007
SOURCE:
How to darken sharp el-520w contrast?
If it can be done, you need to press SETUP then choose CTRST and use your left and right arrow keys to adjust the darkness of the digits on the screen. Unfortunately, some of the older models do not have this ability so if you do not find that that menu option it means that you cannot do it on the calculator.
Jun 25, 2014 | Sharp EL-520WBBK Dual-Powered 12 Digit...
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
The screen is partly shad tv LTV-27W2
What color is the shade? Is it a red/pink shade?
Nov 27, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Shade Guide Table for Neiko Auto-Darkening Welding Helmet
While mig welding I personally use 10 or 11, but it depends on the individual. You want it dark enough (higher no. darker) to protect your eyes from flash burn but light enough to see the weld. Start at the highest setting and go lighter until you can see good enough. No lighter than necessary. I hope this helps you out.
Nov 08, 2017 | Neiko Tools USA Solar-Powered Auto-Darken...
MY VIZIO 42''COLOR IS CRAZY, IT HS BLUE OR PURPLE SHADING, I DONT KNOW WHAT IT IS. ITS ONLY ONE WEEK OLD
Reset it to factory setting,If still getting bad colors shadding.Return it,for a replacement.The backlight video board have problems.
Dec 19, 2009 | Vizio GV42L 42 in. LCD Television
I forget how to brighten my screen...?
To adjust the contrast, follow these steps.
1. Press and release the [2nd] key.
2. Press and hold ↑ or ↓ which are below and above the contrast symbol (yellow, half-shaded circle).
· ↑ lightens the screen.
· ↓ darkens the screen.
Rate me, thanks.
Jul 11, 2009 | Texas Instruments TI-83 Plus Calculator
Red line on screen
something going on w/ the convergence take to tv shop before it will cost lot more good luck shad
May 03, 2009 | Hitachi 43FDX01B TV
"Finger Print" sized shaded area on screen
A shaded or dark spot on the screen is usually a bad pixel area and is caused by being hit or pressed to hard in that area. It could also be that the liquid crystal (LC in the LCD) in that area has become stagnant, try rubbing the area and around the area pressing firmly, just enough to see a color change in the screen area, but not too hard that the area turns black. Rubbing the area will move the liquid crystal around and sometimes refreshes a darkened area. If rubbing doesn't work, then it's a bad pixel area, and will eventually become a dead pixel area with time.
Jul 04, 2008 | Acer Aspire 5050-3242 Notebook
Proima lx2, darkening of the image and slight shake
either the fly-eye lens or the light polarizer is fried due to excessive dust and heat. bad news: you'll have to replace the entire optical engine. worse news: infocus doesn't make them anymore. sorry.
Sep 02, 2007 | InFocus Proxima UltraLight LX2 Multimedia...
Computers & Internet Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
