Compaq Presario SR5710Y PC Desktop Logo
A
Anonymous Posted on Feb 02, 2014
It won't boot up - Compaq Presario SR5710Y PC Desktop
2helpful
3answers
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
2helpful
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
1helpful
Won't boot from dvd or hard drive, changed hard drives and still won't boot
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
Passenger door won;t unlock
CV boot, requires axle disassembly, or you could use an aftermarket, split boot. You MUST replace the lube....
It is often much better to exchange the shaft with a new or rebuilt one. Many vibrations are caused if there is even a minor imperfection in the CV joint.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
