Question about Neff 24 in. S5443X2 Built-in Dishwasher
Intergrated doors i need to change the furniture door on a neff s5443x1 and i dont know how to get the old door off
  • henry1 Jan 02, 2008
    want to remove integrated door panel, cant see how it is fixed
It is quite simple to remove the door panel .around the inside you will see some screws along the edge of the stainless steel panel .these are torx 20 bit size there are usually 2 or 4 that need undoing and are usually the 2 at the corner near the top and 2 half way down the sides these go through the panel and into the wooden door also on some models there are 2 along the side of the stainless panel hidden behind plastic grommets remove the ones from the edge first you can tell if they are the right ones becuase of the length try each one at a time if they are short screw them back in and try the next finally losen the ones at the side if you have them and the door will fall forward lift it upwards with the door slightly closed and it will come of the two metal clips at the bottom refitting is in reverse usin the old door as a template to measure and refit the brackets hope this is of assistance
Posted on Feb 03, 2008
Dishwasher will not start unless I push the door in further
could you please let us know the model #
thanks
sb on the door frame if not go here for a model# finder
http://www.neff-home.com/uk/service/manual
Jan 22, 2018 | Neff Dishwashers
I need to remove the furniture from an old tecnik DW 2677 dishwasher as I have a new one and want to replace the front. I cant see any screws or how to remove it
1 Open door and you will see 5 crosshead screw on each side, undo the top screws and lift up the plastic control panel to release it from the metal clips fixed to the back of the furniture door
2 Lift up the door to release the plastic clips (fixed to the back of the furniture door) from the keyway slot in the metal dw door
3 If its a 2677 that is the replacement the reverse the proceedure on the new one, there is no point cahnging the clips, if its not then
4 Swap over to new makes fixings and rehang the door
Jan 29, 2011 | Tecnik TDW2677 Built-in Dishwasher
How do i change the door panel on an intergrated neff dishwasher
check out www.applianceart.com./ You may not need to change the panel just cover it. They have hundreds of designs and colors and even a stainless steel option
Apr 09, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
Sep 18, 2009 | Neff B1421 Electric Single Oven
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
I have neff intergrated dishwasher, but the door does not seem to stay on. It has two fixings at the bottom and two at the top. Any ideas?
When you open the dishwasher door you will see three screws along each edge. You need to remove the middle screws and replace them with longer ones that will go into the door front as well.
Feb 17, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Mar 28, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff 24 in. S5443X2 Built-in Dishwasher Logo
698 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
