Question about Kenmore Dryers
Stackable Kenmore washer/dryer-- dryer will not start
My dryer was working fine. I took a load of laundry out of the dryer & put the next load in and the dryer would not come back on. There was no noise or anything it just would not restart. I checked the braker box & it was fine & the washer was working fine. Any ideas regarding what the problem might be? And also where are the fuses located (??? do you have to remove the back panel or are the fuses located somewhere on the front?)
Thank you,
Dena Bevins
  • 67 Answers
SOURCE: My Push Start Relay or Control Knob is not starting the Dryer
is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Posted on Mar 21, 2007
  • 156 Answers
SOURCE: Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Posted on Feb 28, 2008
  • 185 Answers
SOURCE: Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Posted on Mar 25, 2008
ezed51
  • 7 Answers
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
Posted on Jun 01, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Posted on Sep 25, 2008
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
When I put a light load into washer, follow directions, the washer starts by running water but does not go into next cycle
I would check the lid switch. If switch is faulty, it will allow unit to fill like normal, but won't agitate or spin.
Nov 15, 2015 | Kenmore 24 in. Gas Laundry Center with...
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
Seperate washer and dryer
Unfortunately, your washer and dryer are part of a "laundry center". Which means, the two together are one system. They cannot be separated. You can still use the dryer, obviously. Have you considered fixing the washer?
Jun 21, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
163 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
