Question about Whirlpool Duet GHW9150P Front Load Washer
Washer problems the washer stops and reads out f-6 and then beeps and stops completely i have had several service people out here and all they do is play with the front of there underwear ,can you please tell me what i should do to fix this issue i have tried all the manual says and even run it threw its test cucles and those go good ,,thanks cb
  • docpam Nov 06, 2007
    washer will not run - i press the start button it makes a clicking noise but will not start the cycle.
  • Anonymous Mar 07, 2008
    My Whirlpool Duet Front loader same problem, sometimes I have to leave it unplugged for almost 24 hours. Will come back on do about 3 loads and do it again. Machines powers on, but when I press the start button it just does a short ding, and will not come on. Very upsetting. Then when it does come back on it keeps telling me Code error F70. Get this, know one seems to know what this code means.
  • 146 Answers
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excess water in the washer. Re-select the cycle and press HOLD TO START. If the problem persists, call a service tech.
Posted on Nov 06, 2007
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ... > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
IDW450 dishwasher starts working then after about 7 minutes stops - beeps about 6 times and stops completely - the dishes are wet but the dish washer tablet door is not open . - can anyone help - then on...
There is probably a leak under the tub., Water drips into a catch pan and sets off the beeping. Take the kick panel off the bottom front and see if there is any water in the pan. If there is you can drain it or blot it. BUT this is an indication of a bigger problem. You might want to run it after you dry the pan and see if you can spot dripping water when using a flashlight.
Jun 06, 2013 | Dishwashers
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
Washer is turning on and off water starting and stopping
Hi just read your posting.When you say 'It stops completely" does that mean the machine turns off with no lights or display on the top panel?Or when it stops completely the machine beeps and a series of lights light up or an error code appears in your display if you have the display model?Please reply with additional information on the questions and I am sure I can help you rectify this problem
Jul 17, 2010 | Fisher and Paykel WL26CW2 Top Load Washer
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
F 02 reading on front loader washer.
I found several helpful sites from owners who had the same problem and they got the issues resolved, will try what they advised and if that don’t work I’ll call a service technician.
Oct 01, 2009 | Kenmore Elite 45986 Front Load Washer
The wash beeps all the time
To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is started.
Nov 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Check Wire harness connections between the Drive Motor and the Motor control and between the Motor and the Machine Control
The Drive Motor is fauilty
The Motor Controller is fauilty
sorry if you still have a warranty call for service
Oct 17, 2008 | Kenmore Elite 45986 Front Load Washer
The dreaded F code.........
The problem you are having is a well known problem with the Kenmore Oasis washer. The user interface board (control panel) has been known to fail on some models which causes the annoying beeping and erratic display. I work on these machines and have never heard of any interference from certain frequencies causing problems. If that were the case, it would make sense to believe that you would have problems with other appliances in your home (particularly television and radio). The only fix for the problem is to replace the user interface board in the control panel as the board is not serviceable. I hope this sheds some light on the problem and gives you a little insight on what has actually been a common problem (I've replaced 8 of these boards within the last 6 months).
Oct 09, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washer keeps beeping
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
