Question about Numark DVD01 Dual DVD Player
Controll panel is not working.no display.dvd is loading ok
  • djfred256 Nov 06, 2007
    No control panel display on right side. DVD loads okay...
  • 515 Answers
This seems to be a common issue with this model. Try replacing the jumper cable on the unit (which goes from the CD Tray Unit to the CD Head/Display Unit). If that does nothing, you will need to get it serviced professionally, as this would then be an internal issue.
- TWEAK A/V LAB
Posted on Nov 14, 2007
Need to align ink cartridges
Follow the steps to align newly installed cartridges.
  • When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  • Press the button next to OK on the control panel display.
  • The product prints an alignment page.
  • Place the alignment page print-side down on the right front corner of the glass.
When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer
  • Double-click the HP Digital Imaging Monitor icon ( ) on the lower right side of the Windows taskbar.
  • The HP Solution Center displays.
  • In the HP Solution Center, click Settings . Then click Printer Toolbox .
  • The printer Toolbox displays.
  • Click the Device Services tab.
  • Click Align the Print Cartridges .
****If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 05, 2013 | HP PSC 1210 All-In-One InkJet Printer
Dvd will not load
Hello
If the power supply is OK, and there is display and all others, the fault will be due to a loose loading belt, or defective loading mechanism. It will be best to replace the loading mechanism rather than try to repair it; provided power supply is OK.
Jan 06, 2012 | Philips DVP3962 DVD Player
How do I clear Fax log entries for HP J4580?
You can try this,
"A 'Fax Log Full ' message displays on the control panel display when the Fax Log is full."
1. Press the Setup button ("Spanner logo")
2. Press the Right arrow button (?) until Tools displays on the control panel, and then press OK .
3. Press the Right arrow button (?) until Fax Log displays on the control panel, and then press OK .
4. Press the Right arrow button (?) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
5. Press the Cancel button (X) to exit.
Hope it helps.
Jul 14, 2011 | Computers & Internet
Machine reads document jam,checked machine seems ok,cannot sent fax.
Hi there!
The error message that you are getting means there's a jammed paper inside the machine particularly in the feeder. This may also appear if the panel is not closed securely. Try to open the control panel and look for any pieces of jammed paper or debris. Closed the front cover or the control panel, it should display the regular screen date/time. Once you have the regular screen load the document on the feeder, the display should change and should ask you to enter the fax number.
Hope this helps!
Please rate if it worked, Thanks
Mar 30, 2011 | Office Equipment & Supplies
Toshiba DVR19DTKB2 user manual
i have a dvr19dtkb2 video and dvd freeview recorder it has froze on channel 800 tried unplugging it still froze when turned back on can you help please
Oct 12, 2010 | Televison & Video
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
TV w/ built in DVD
Hi maybe this might work on your dtv,try load a post card the size of a dvd and hold it in then try the source button to change to tv mode.It worked on my dtv-265-d now all i need is to get a remote control.
Aug 09, 2008 | Mintek DTV-263 26 in. LCD Television
No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
Apr 12, 2008 | Polaroid PDV-0813A
Getting sub titles to work
hi glad to help you follow these instructions they should be easy to follow but if you have any problems give me a shout back ok good and hope you lady friend can enjoy all of her films now just remember to select the right language and you should have no problems.
Thanks for using the site and glad to help let me know how you get on ok
Step 1:
Set up your Sony DVP-C660 CD/DVD player. Make sure your remote control is functioning and you can see the display on the TV screen. Load a DVD.
Step 2:
Press “Display” on your remote control. This opens the menu.
Step 3:
Use the arrow keys to scroll down to the “Subtitle” option and hit “Enter” to select it.
Step 4:
You’ll be given a list of languages available on the DVD. Choose one and press “Enter.”
Step 5:
To turn subtitles off, select “Off” instead of a language.
Mar 08, 2008 | Cyberhome CH-DVD 300 DVD Player
Numark DVD01 Dual DVD Player Logo
70 people viewed this question
Top Numark Televison & Video Experts
Are you a Numark Televison and Video Expert? Answer questions, earn points and help others
