I have a frigidare gallery model 41739012891. It will wash but none of the spin cycles seem to be working properly. There is currently water in it that won't drain. Is it a timer problem or something else
Ok, check the following before you replace the timer. in most cases, the washer will not spin if there is a drainage issue. please check the following below and, if everything concerning the drain assembly checks out ok, then , replace the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
