Question about Arris WA840G 802.11g/b (49832000100) Wireless Access Point
What should I do after "Easy Software Setup"?
I followed the "Easy Software Setup". The configuration is completed. I have two questions.
1. When I acessed the Web-based configuration utility, I saw much simpler screens than those in the User Guide.
2. I will use WA840G as an access point. What else should I do after "Easy Software Setup"? Should I just unplug the ethernet cable from the computer and plug it into the router?
  • 156 Answers
Just unplug the Ethernet cable from the computer and plug it into the router and put the other end of Ethernet cable in to the wan port of WA840G
Posted on Oct 25, 2007
Set up printer.
Step by step set up printer with wireless connection
1. Insert CD Driver came with your printer and run the [Setup]
2. Then klik [Next] to perform the image below
3. Select and Click Wireless LAN Connection, Then Click [Next]
4. Select and Click Acces Point Connection, Then Click [Next]
5. Ensure that your printer is turn on, make sure the white power lamp is on and then click [Next]
6. The sofware will now briefly search your network for any printer already connected. If this is first time you are setting up your printer it will not be found. So please ensure that [setting printer could not be found on the list] is selected, then click [Next].
7. The setup Guide installation will now start
8. Click on [Next]
9. Click on [Cableless setup]
10. When the following screen appears, hold down the [Wi-Fi ] button (A) on the printer until the white power lamp flashes 2 times and release after the second flash, then click [Next].
11. Make sure that the blue Wi-fi lamp flashes quickly and the white power lamp is lit, then click [Next]
12. The following message will be displayed
13. Once the connection to the acces point is completed click [Next]
14. When the following screen appears, select your region and click [Next]
15. When the following screen appears, select your language and then click [Next]
16. When the following screen appears, select the software you wish to install, and then click on [Next]. If you're not sure which software you want to install at this stage, don't worry, as you can always uninstall it at a later stage if you wish.
17. When the following screen appears, click on [Yes] to agree to the end user license agreement.
18. When the following screen appears, click on [Next].
19. The software will now instal
If the following screen is displayed during the installation, click on [Redetect] to search for your printer again.
Depending on your network configuration, it may take a minute or so for the software to detect the printer. This may involve clicking on redetect a number of times.
20. Once the Cableless setup is complete the following screen will be displayed to indicate the model of your printer and the name (or SSID) of your wireless network. Click [Complete].
Mar 24, 2016 | Canon PIXMA Office Equipment & Supplies
Is replacing the Body Control Module on a 2004 Nissan Titan as easy as removing the old one and plugging in the new one?
The answer to your question is no, The BMC controlled directly by the BMC are.
1. Power door lock system
2. Remote keyless entry system
3. Power window system
4. Sunroof
5. Interior room lamp
6. Warning chime
7. Turn signal and hazard warning lamps
Configuration EKS00777
CONFIGURATION has two functions as follows:
? READ CONFIGURATION is the function to confirm vehicle configuration of current BCM.
? WRITE CONFIGURATION is the function to write vehicle configuration on BCM.
? When replacing BCM, you must perform WRITE CONFIGURATION with CONSULT-II.
? Complete the procedure of WRITE CONFIGURATION in order.
? If you set incorrect WRITE CONFIGURATION, incidents will occur.
? Configuration is different for each vehicle model. Confirm configuration of each vehicle model.
If CONSULT-II is used with no connection of CONSULT-II CONVERTER, malfunctions might be
detected in self-diagnosis depending on control unit which carries out CAN communication.
This came right out of the 2004 titan manual don't think it's the answer you wanted to hear.
Mar 31, 2015 | 2004 Nissan Titan
Hey. :) My name is Peyton. And me and my Dad have just bought a "NetGear N150 Wireless USB Adapter", And we've looked at the intructions, and we looked it up. But we can't seem to figure out how...
Installing the Software and Adapter
To install the wireless-N USB adapter with custom setup:
1. Insert the Resource CD. If the CD main page does not display, browse the files on the CD
and double-click Autorun.exe.
2. Click Install the Software.
Select one of the following methods to configure and manage your wireless network:
Smart Wizard. Allows you to manage your wireless networks with the NETGEAR
WNA1000 software and to connect securely using Push 'N' Connect.
Figure 1-1
Figure 1-2
NETGEAR Wireless-N 150 USB Adapter WNA1000 User Manual
v1.0, August 2009
- Configure network manually. Specify the settings for your wireless-N USB adapter
in the Settings screen.
- Configure automatically. Allow the Smart Wizard to automatically configure the
settings for your wireless-N USB adapter.
Windows Utility. Connect to and manage your wireless networks using only the
Windows configuration utility. For more information about Windows utilities, see the
Windows documentation or the NETGEAR application note at:
See page 1-3 of the manual:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Computers & Internet
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
Jul 31, 2010 | Canon CanoScan 3000ex Flatbed Scanner
I dont have a user guide for connecting to my componants
Your remote needs to be configured to control your devices and setup your activities. To do this, all you need is the remote's application setup software which is downloaded from the Logitech support site. Once you download and install the software, it basically starts an 'interview' process and asks you the types, makes and models for the devices you have. In many instances, the default settings and configurations that are created work out just fine. Once the configuration has been completed, you connect the remote to your computer via the USB cable and the software updates your remote. The only thing you need to do before you begin working with the software is to inventory and jot down the devices you have and how they are hooked up to each other. Then it is a simple matter to walk through the software configuration and plug it all in. Here is the link to the software download site:,en
Hope this answered your question. Good luck!
Jan 23, 2010 | Logitech Harmony 880 LCD Remote Control
Computer won't let me acess any software
Windows XP
1)Try the following steps, hard boot the notebook, before the post bios completes press F8 on the keyboard, you will see the boot options, choose last known good configuration, or Safe Mode with Network support.
2) If number 1 did not work then insert the windows installation disc, boot up the notebook and enter the bios either by pressing F2 or F10 or Delete, change the boot sequence to CD-ROM as your primary boot device. Remember to change this back when you have solved the problem. now the notebook will display the following: press any key to boot from CD-ROM, Press any key, now let the setup progress till you see the setup console, continue with a standard installation till you see the text "Press R for the Recovery console" now you will see a text e.g. c:\windows (1) now press 1 on the keyboard this is your root directory. now type the following and fixboot (Enter) your answer will be (Y) at all the prompts. then you type fixmbr (Enter) follow the prompts with (Y)
After it has completed the operations type Exit to exit the Root Directory. Reboot your notebook.
If this did not help please specify any other questions, and or any error messages, beeps.
May 24, 2009 | Acer Aspire 5520-5908 Notebook
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Arris WA840G 802.11g/b (49832000100) Wireless Access Point Logo
204 people viewed this question
Top Arris Computers & Internet Experts
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
