If you are in Windows 7, on your laptop, right click on an empty area of your screen. Click, 'Screen Resolution' from the choices there.
On that screen, go down to 'Orientation:' and select 'Landscape'. If 'Landscape' is already checked, choose 'Landscape (flipped)' from the choices. Click OK to save your changes. If you are running different Operations System advise.
SOURCE: my asus x59sl cam is upside down helpe me
There is a setting for the camara. Find the camera in the device manager then use the right button and click for properties , if that don't work look in image etc setting with the control panel select your camera, right button click, properties or it may be called settings and either tick or untick the 90 degree rotation or upside down setting
SOURCE: asus k50 notebook, display is upside down on the
im thinking you have windows 7. go to the control panel and click on display property . you should see a advance tab this will give you options for the display.
WEBcam Image Settings
Check the WEcam settings. Most WEBcam have a setting to invert and mirror the image
SOURCE: my webcam displays upside down on my Asus laptop
my laptopo it,s upside down how i am changing
