Nordic Track NordicTrack T5.7 Treadmill Logo
A
Anonymous Posted on Feb 02, 2014
I feel a vibration when walking or running on the treadmill
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Nov 09, 2011
SOURCE: I have norditrack c1900 series
Watch this videos:
http://www.youtube.com/watch?v=JC72OIKdluY&feature=related
http://www.youtube.com/watch?v=AZSMLpXm-tA&feature=related
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
Nordic track commercial 1750 treadmill. over the last day or 2 it has developed a humming that gets more pronounced the faster you go as well as what feels like a small vibration
Try to lubricate the treadmill deck and belt
Watch the video to know how to lubricate the treadmill.
Treadmill walking belt lubrication
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
1helpful
Worked fine for a year, now feels very strange walking on it, have tried lubricating but does not help, feels like bouncing or vibrating while walking, what can be done?
Treadmills often vibrate, just a common side effect of running on it.
Location of your treadmill is key most of the time for reducing vibrations or noise due to impact.
This impact is spread to the floor from the feet of the treadmill, which is a small surface area.
You want to make sure that your treadmill is leveled and it is best that it is placed on a rubber treadmill mat.
This will absorb the impact, as well as the sound and the shock of the vibrations.
A thick rubber mat will act as both a sound and impact suppressor between you, the machine, and the floor. The thicker the mat, the better.
If this does not fix the issue, we would be happy to help you further diagnose the problem by phone 888-713-2880 or by chat at www.sportsmith.net
We also have rubber mats available for your treadmill if you need a new one! Otherwise, good luck on the repair :)
2helpful
Proform tredmill---stops after a couple of steps--will start back up after getting off---motor control board?
Inspect the walking board and belt first.Feel the tecture at the outer edge of the belt, then feel the center. If it feel fuzzy, the walking belt is worn.
Check the walking board for damage, deep scratches, excessive friction will cause an over current shutdown of the controller.
If the walking belt and board are good, lubricate the walking board and belt and try again.
Does the motor spark allot when running?? This will also cause over current.
Have you tightened the belt (too tight??)
After covering these suggestions, if the same problem is apparent, change the motor controller..
I have noticed a few times that my f3 life fitness treadmill changes pace on me, and so does the incline. i can see it on the monitor, also it has started feeling like the belt is catching or something, or...
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
1helpful
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
1helpful
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
The belt is making a scraping noise when you walk on it. i see nothing touching the belt proform crosswalk 375e
Unplug the treadmill then loosen the running belt and physically feel the full length of the deck and then chick the entire running belt something is stuck causing the scrapping.
I've had my treadmill for a good while now(about 6 years) and have used it A LOT. However, now it just stops on me after about 35 minutes or so. The controls continue to run, but not the belt. Have I just...
If the treadmill slows down or cuts off when warm it is probably a worn or dry walk belt.Lift the edge of the walk belt and feel the underside of it about 1 inch from the edge,now compare that to the underside of it in towards the middle where your feet are stepping on it,if that area feels alot more frayed or fuzzy the walk belt is worn.Now rub your hand on the platform surface where the walk belt rides,you should feel a wax film on the platform,if not you can purchase treadmill wax from the manufacturer,retailer or on-line.Apply the wax under the belt in towards the center 2/3 of the belt area,that should be done whenever you don't feel that wax film when you check it.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
