Question about RCA F36705 36" TV
High Pitched Ticking Noise
I have a F36705 RCA tv that makes a high pitched ticking noise in the back.  The TV won't turn on at all.  The ticking noise decreases in frequency once unplugged, then goes away completely.
  • 2 more comments
  • Todd Williams Oct 25, 2007
    The service number is F36705YX1.  Will I have to do any soldering to replace?
    Thanks,
    Todd
  • Todd Williams Nov 09, 2007
    I replaced the two parts and the TV worked good for 1 week. Now it is doing the same thing. Did I buy faulty parts? I got them from a place called MCM Electronics.
  • Todd Williams Nov 10, 2007
    So can I get away with just replacing the transistor this time or do I need to do both?
    Where is the best place to get this, they all claim to be OEM sellers?
    Genius:
  • 1,694 Answers
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Posted on Oct 25, 2007
  • 2 more comments
  • Vista Electronics Oct 25, 2007
    Both parts soldered in  Part #'s 241319 or ASTI 2170 xformer
          and 237470 transistor ........T.
  • Vista Electronics Nov 10, 2007
    Might be some bad solder connects in horiz driver circuit....
    More likely, you used a generic sub for the 237470 RCA
    transistor = generics are seconds = they run hot, only last for
    a few hours = you must use OEM or equiv.............T.
    Please rate solved! Thanks......
    Just the transistor 2SC5148 FIRST quality only with
    237470 being least expensive.........................T.
  • Vista Electronics Nov 12, 2007
    Andrews Electronics = 1-661-257-7700 or www.............T.
    237470 must be the part # ( RCA ) that you pay for to be the real deal ! Or Sony or Hitachi or any Mfr. that offers to
    sell a 2SC5148 ..........if it is the generic number on
    the part only ( no Mfr.# ), then it is a second or worse
    as to quality................This comment applies to
    horizontal output transistors in general.......................T.
SOURCE:
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Y rca 27f500tdv tv high pitched noise
Change the horizontal IC are damaged
Jul 28, 2009 | Televison & Video
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
Sometimes screams a high pitched noise when turned on
the high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
Oct 27, 2008 | RCA HD52W56 52" Rear Projection HDTV
High Pitched noise returns after new parts installed.
Use first quality OEM or equiv. transistor, RCA 237470 is
least expensive...............T.
Nov 09, 2007 | RCA F36705 36" TV
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Televison & Video Logo
342 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
