AC pump won't engage on 93 Chev Surburban. Don't know if it is dash switch, low pressure switch or low charge. Where do I start? I have gauges.
Sounds like LP switch. Evacuate rge systen, add one can of freon, Then start again, turn on ac and ck clutcg.
On the canister on the passenger side under the hood there is a plug onto the canister remove and put a jumper wire in the plug the compressor should come on. if not the compressor is bad
if it comes on while its running add freon and see if that helps
