Question about Performance Teknique ICBM-771 Car Audio Amplifier
No Power I've just purchased a brand new 1000watt Boss GT 580 and after installing it i'm having some trouble powering it on. I've tried several things as i originally thought it was the remote, but i took a wire for the remote directly to the 12+ to bypass it and still no power. I'm having trouble believing it is the amp so i replaced to power cable and still no power. It would seem now more clear that it must be the amp, but i'm still not convinced. The reason i feel this way is because when i took the power cable and stuck it against my ground cable i didn't get any sparks. This leads me to think that it has something to do with my cables.....would it be possible that my ground cable needs to be moved, would that cause it to not power? Thanks,2 15's waiting on power
  • js14 Oct 29, 2007
    the problem had to do with the length of space between amp and the battery...i've placed my amp mid car now until i can re wire with a 4g instead of the current 8g wiring. thanks for your help
Your remote power cable is probly not connected right or your ground is not grounded right make sure you dont have any paint at the ground spot if you do scratch it of completly and reconnect
Posted on Feb 19, 2009
    Novelist:
    Champion:
  • 218 Answers
Check with a 12 volt light bulb of some sort.  First test +12 volt  wire to the chassis of the car.  The bulb should light.  Then test +12 volt wire to the ground wire.  If no light then no ground is present.
Posted on Oct 26, 2007
Why did it stop working?
Big Boss™ Oil-Less Fryer - BedBathandBeyond.com
www.bedbathandbeyond.com/.../big-boss-oil-less-fr...
Bed Bath & BeyondHome > Gifts by Interest > Healthy Living > Big Boss™ Oil-Less Fryer. "Big Boss™Oil-Less ... Right size for family cooking, fried taste without oil, does what it is supposed to do ! ... I purchased a new one when my old Big Boss stopped working.
Big Boss Oil-Less Fryer Reviews and Complaints - Genuine ...
www.asseenontvonsale.com/kitchen/big-boss-oil-less-fryer/
Feb 22, 2012 - The working of Big Boss Oil-Less Fryer is very simple. ..... I am returning it because it does not work (does not turn on) but I don't want another ...
BIG BOSS KITCHEN PRODUCTS - Facebook
Dec 25, 2015 | Big Boss Oil-less Fryer
When used, it seems to effect guitar amplifiers and cause a strange sort of a chorus sound, like somehow the unit is bleeding into the other amps.
it maybe interference picked up through an unsheided or poorly sheided cable or through single coil type pickups rather though the amp itself. You might also try get your power for the amps and this unit through different circuits.
Mar 20, 2015 | Roland Boss VE-20 Vocal Performer
Power loss
950 watt is very small. Most electrical appliances need 1000watt to operate so if the vacuum cleaner is 1000watt then the gen set will trip. Check the drill as it is possibly 850watt which the gen set can handle. It all has to do with the wattage of the equipment you intend to run from the gen set
May 09, 2013 | Winco 5500 Watt TriFuel Power System w/...
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
I bought a brand new 170.00 battery for my Dell studio 1737 laptop. It continues to say plugged in, not charging. What can i do? I've tried plugging in and replugging in the charger.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Or you can visit http://www.batteriescenter.com.au/.
Jun 19, 2011 | Dell Studio 1737 (Studio 1737-RubyR) PC...
Hi, I recently purchased a Samsung Q330 with windows 7 home edition installed. About a week after owning it I was prompted to download the windows updates of which there were about 49. After these were...
The update messed up the OS. I would go into Safe Mode (tap the F8 key while the system is booting up) and then uninstall all the updates or go back to the previous System Restore point (from Start -> Programs -> Accessories -> System Tools -> System Restore).
Jan 25, 2011 | Computers & Internet
I powered off my dlink DI 704P and internet modem by turning off switch on surge suppressor (which I have do several times) and just powered back up after 3 days and my dlink will not come back up no...
1. if you have a power adapter connected to this router it may have burn out when restoring power several times in the way you shut down.
2. When visiting the manufacturer website and researching your unit I found that the unit is "discontinued" and there is no other support for it.
3. I suggest that a new router be purchase with update technology to get the most from your internet experience.
I hope this helps. Have a great day!
Aug 23, 2010 | D-Link DI-704P Router
Boss BV9055 Power Up Problem
12/29. I actually figured this one out myself after reading posts concerning parking brake over rides. It turns out that the Boss BV9055 will not powerup if the pink parking brake wire from the units wiring harness is not grounded. Once I grounded that pink parking brake wire the unit did power up.
Dec 28, 2008 | Boss AUDIO SYSTEMS BV9055 Car DVD Player
Orange connectors (3.3v) brown
thats probably dust and static dirt, if the power supply worked fine before then there should be no problem providing that the pin arrangement is the same, test it on you old mobo to check it!!!!
Nov 14, 2008 | HEC Group ACE 580UB 580-Watt Power Supply
On power up.......protect light comes on
what are the resistors connected to? mosfets?if so you need to identify which pin gate or source,these amps have dual so the other side would be the same.
May 04, 2007 | Boss IQ 1080.2 Car Audio Amplifier
Performance Teknique ICBM-771 Car Audio Amplifier Logo
150 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
