Question about Xante CL30 HSE Laser Printer
Xante CL30 printing streak line in middle of the paper
My Xantel CL30 is printing a streak line in middle of the printer. We changed the roller pins and still the problem exists. Any insights are helpful.
  • Anonymous Jul 23, 2008
    Five or six fine black lines running about 4 inches from side of paper
  • 3 Answers
Make sure there is nothing on th belt of the unit
Posted on Nov 08, 2007
Xante cl30 printer drivers for windows7 32bit & 64bit
go to -->support -->drivers & docs -->legacy products -->cl30
Aug 20, 2012 | Xante CL30 HSE Laser Printer
Paper keeps jamming in the fuser. I have tried setting the levers in both directions - not sure which is the correct positioning for them, as it doesn't seem to make much difference.
if you have many jams in the fuser probably the roller have dry toner attached to them. print a heavy paper - 300gsm - without any color, just a small dot. see if the paper comes out of the fuser and if it;s dirty or not. repeat that until the pages com out clen - both sides. then print what you have again,
Apr 11, 2011 | Xante CL30 HSE Laser Printer
I have the cl30. It prints fine except photos and
it's not a photographic print. even with thew best photo paper you will not have the best qualiy
May 13, 2010 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Feb 13, 2009 | Xante CL30 HSE Laser Printer
Paper Tray Oki /Xante ?
It sounds as if maybe the trays are not configured in your software. Access the printer driver and make sure that the additional trays are enabled. Under the Device Setting tabs, if on PC, available trays, ensure that you have the correct number of available trays selected.
??? If that doesn't work, you may want to check back with Xante to make absolutely sure they do not have the trays in question.
p/n 250-100075
Jun 19, 2008 | Xante CL30 HSE Laser Printer
Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
May 02, 2008 | Xante CL30 HSE Laser Printer
Xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Mar 06, 2008 | Xante CL30 HSE Laser Printer
Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Xante CL30 HSE Laser Printer Logo
359 people viewed this question
Top Xante Office Equipment & Supplies Experts
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
