Belkin Surf N300 Wireless Router (722868807347) Logo
A
Anonymous Posted on Nov 11, 2017
N300 router will not allow my apple hardware to print to my air printer
My previous belkin router worked fine until it burned out. I now have a belkin N300 and everything works ok except my ipad, and apple mac will not talk to the air printer anymore. My old Windows PC works fine, and I can connect my MAC etc direct to the printer. I suspect there is a problem with N300 and bonjour. How do I fix it?
Jose Ma DM.
Level 3:
  • Master 540 Answers
  • Posted on Nov 11, 2017
Jose Ma DM.
Master
Level 3:
Answers
540
Questions
0
Helped
177118
Points
1776
Hi, yes it could be a problem with bonjour support in router, maybe you need to update firmware, the steps to do it are in the following link: Updating your Belkin routers firmware
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jun 25, 2010
SOURCE: I have a Belkin router N300 do I just plug in the
To make my Lexmark e250DN work on the network using my new Belkin N300, I had to do this:
1. Install router as per Belkin instructions. 2. Power off printer, then connect Lexmark printer to the router. Power on printer. 3. In a Browser, go to 192.168.2.1 which is the Router's IP address. 4. Click on DHCP Client List. You will see a list of the "computers" connected to the router, which includes the printer. Your printer will have a very long alphanumeric Host Name (mine began with E00000) Note the IP address (something like 192.168.2.4) That is the printer's IP address. 5. In Control Panel, Printers & Faxes, a) if the printer was previously installed with a different router, edit its settings to use the new IP address; b) if the printer was not previously installed, ADD a Network Printer at address http://192.168.2.x (x being whatever your DHCP client list showed).
That should do it.
Testimonial: "Thank`s Great help, I will try it!"
Anonymous
  • 9 Answers
  • Posted on Nov 30, 2010
SOURCE: how to connect my belkin
No, that will not work.
The USB Port in the router is for sharing the USB Storage....
You can use only, RJ45 cables...
Tom Marvolo
Rakesh Warrier
  • 708 Answers
  • Posted on Dec 26, 2010
SOURCE: cannot connect to the internet on my laptop via
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Tom Marvolo
Rakesh Warrier
  • 708 Answers
  • Posted on Jan 22, 2011
SOURCE: can ps3 connected to belkin
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Tom Marvolo
Rakesh Warrier
  • 708 Answers
  • Posted on Jan 30, 2011
SOURCE: my Belkin Surf N300 gets connected to internet and
Uninstall The Belkin Setup/Router Monitor From Control Panel
Regards
Tom
2answers
Im looking for Belkin router N300 F9K1002's driver
If you don't want to use the setup CD you can manually enter it and make changes. Here a video I made of me setting up my F9K1003V1
How can i get belkin n300 to recognize motorola SB6141?
Well kindly reset the belkin N300, try connect, most probably will get connected....By the by, which mean are you going to connect both? is through lan cable or wifi?
1helpful
My mac laptop can't connect to belkin n300 router wirelessly
There is a small piece of paper underneath the router with original passwords, and the default was WPA security.
Hold the reset in the back till it cycles to remove any custom settings.
3answers
Dell V510 printer worked fine wirelessly until we got a new Belkin Router
The printer's IP address most likely needs to be changed.
Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
2helpful
I'm installing a Belkin N300 wireless router using a desktop PC with a wired interface card for the installation. Will this work if I connect the PC to one of the LAN ports on the Belkin router, and...
you can only comunicate one way not both ways disable wireless apps and windows will find a conection by wired and accept.therfore will always ose the ared until is changed to another method. if password is required thats is yours to know.
How to install belkin surf wireless router N300?
Hi Friend,
Please read this pdf file...it will help you for installation
http://docs.google.com/viewer?a=v&q=cache:ViTLfewsf9MJ:en-us-support.belkin.com/app/answers/detail/a_id/4861+belkin+wireless+router+n300+review+installation&hl=en&gl=in&pid=bl&srcid=ADGEESgAExquF1wvYD_BDm4Xejb0doz6IBGAB73NO1C5LsarXb5qj_Ouuu7RnE_k6D8oX_MOh-xE57DN69Kxpqc6TxENHgKaafqaSrtZhpdC8vCAfQmibVd3azzPcpSFQYE-wfbDjYTb&sig=AHIEtbSAUbX8W4HrpZJ_Sopmbm2UfeM7Ew&pli=1
Thanks and Regards
Trinoj
3helpful
I have a Belkin router N300 do I just plug in the printer Lexmark cable to the router and that is it.
That should do it.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
