When i put my ps3 on none of the playstation settings will load what should i do?
Be sure to backup your settings/games saves by doing a System >
Backup on your PS3 or you may lose your game saves! Also, this is a
last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format
via System > Format. (will take approx 3 1/1 hours). You may need to
have our AV cables ready if your using HDMI (in case HDMI isn’t
detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
this will reset everything and make it like the day you brought it so u will lose alot of info but you will bebale to use it again
