Question about OKI C5300n Led Printer
Oki C5300 toner "leaking" on to surface
OKI C5300 print out has "toner" blotches which appear to be from toner that has leaked out of one of the cartriges on to the belt that carries the paper through the printer (same location on the paper as the belt).  Once we clean the belt off, the first few prints are clean - after that, more toner blotches - please advise
    Sniper:
  • 97 Answers
1 - take out all consumables
2 - use canned air to clean interior (do it outdoors)
3 - spray toner cartridges to remove stray toner (keep them connected to the drums, do not separate)
4 - make sure toner carts are properly installed and locked down
Posted on Dec 08, 2008
Why is it putting black blotches of ink all over the paper?
You might have a leaking drum. Or toner might have spilled in the printer during a cartridge change. if you have a HEPA Vacuum with a soft bristle brush lightly vacuum any spilled toner in the printer and try again.
Apr 14, 2015 | OKI B4600 Printer
Oki mb470 pages are not printing properly
It may be time to replace the drum. Check to see if the light spots are random or if they appear at regular intervals. Regular intervals would indicate something in the paper path, typically the drum. But don't rule out the fuser.
May 01, 2014 | Oki Electric Industry OKI MB470 (A4) Mono...
Wide yellow line and blotches in blue background
he poor quality in OKI LED color printing might be fallen on one of the following problems:
- Toner is almost running out
- Drum is scratched or its life almost terminated
- Belt is scratched or its life is almost terminated
- Fuser is scratched
- LED Print head is dirty.
Depend on the knowledge and experiences of each person, the solution is solved easily or takes much time or much labor as well as money This is my suggestion that I have learned from my experiences on OKI C3200, C5300, C6100, C330 that I own:
- First, you should have extra printer accessories suchj as toner and drum cartridges (Y,B, C, M) and fuser, belt for reservation. I think you should have them since someday your printer must need them after they reach to their life limitation.
- Test one after one with the good ones. First testwith tonner cartridges. If the test is OK then continue to test drum cartridges. If it is OK then test fuser and so on. Finally if it is OK, then you must look at the LED Printer heads.
Below is the bad print-out:
:hbc-error.jpg?w=183&h=296After following the steps that we suggest, we found the LED head above the red drum is dirty. Below is the picture after it is clean:
hbc-ok2.jpg?w=181&h=300
Oct 25, 2013 | OKI C3400N Single Pass Color Printer
Prints blotches and marks down the left edge
Hi
That sounds like classic wear and tear issues. All those rollers and gears have very close tolerances and any variation out of the rang and the paper grabing and jamming starts. And that could be cause of the toner leaking. You must have a lot of miles on that ol girl and you got your moneys worth out of her. They dont make them like that anymore and I dont think you could find the parts even though that was back when they supplied parts. I asked an engineer once "couldn't they make that one gear out of metal like the rest of them?" He replied "well sure, but there wouldn't be any money in that..." You beat the system on that one. Time to start your research on a replacement I'm afraid.
Jun 18, 2017 | OKIPAGE 12i Led Printer
How to clean an OKI B4100 (new toner, blotchy printing)
Open the cover, remove the cartridge and vacuum carefully the interior. Clean the leds when the cover is open and it should work.
Apr 04, 2010 | OKI B4100 Laser Printer
I have and OKI C3400. My printer is showing globs
yuo have a leaky black toner cartridge
take out the cartridge and look for damage
aslo check the fuser for damge or leaks
replace any damaged cartridge
Mar 22, 2010 | OKI C3400n Laser Printer
How to do borderless printing with an oki c5300
You cannot do borderless printing with a toner/fuser based unit.
The printer needs a paper grip area and cannot print to the edge due to the fuser.
Sep 30, 2009 | OKI C5300n Led Printer
OKI Laser Printer C5300 printing on paper with black flecks
IF you are using after market black toner then we found your problem. Putting a real toner on now wont help cause dodgy toner is now in the drum, you need to replace Black drum and use real toner. If you are using gen OKI toner, then just replace the Black (K) drum.
Clean led head and these printers dont need a teco, they are designed for wearing parts to replaced by operator ie Transfer belt, fuser, drums and toners.
Nov 20, 2008 | OKI C5100n Laser Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
OKI C5300n Led Printer Logo
671 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
