Question about Brother MFC 420CN All-In-One InkJet Printer
Locating my system can not locate my printer
  • CJONELLO Apr 21, 2008
  • 4,402 Answers
Posted on Dec 18, 2007
Needm location of reset buuton on HP C6180 All-in-One printer
Please click An Ink System Error Code Displays on the Front Panel to access the steps that should resolve the issue.
If issue still exists, then the printer need to be serviced.
Dec 18, 2011 | HEWLETT-PACKARD Office Equipment &...
Windows Manual Printer Removal
There are times when a printer, even though you uninstalled it, will still stay in the system and affect programs or even the startup of Windows. When this happens you need to manually remove the printer. Here is how to do just that.
Uninstall the printer via control panel. Next you will want to check the spool driver location and registry settings.
Reboot the system in to Safe Mode via F8 at statup. Remove the printer from the registry:
locate the key below and remove the printer via its name:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Contro l\Print\Environments\Windows NT x86\Drivers\Version-x\printer_name
Next you will want to remove any drivers left over in the system. Locate the file location below and remove the directory named your printer model.
%SystemRoot% represents your system folder within your windows installation folder. Typically c:\windows\system or c:\winnt\system.
Reboot the system and see how it goes.
Good Luck!
on Jun 12, 2010 | Office Equipment & Supplies
I WANT TO DOWNLOAD AND INSTALL hp psc 1210 inkjet printer to my computer.
Go to HP's website, find the printer driver, download it to your desktop or other location on your computer. Go to your control panel and select printers, select add a printer. When it asks for a disk, browse to the location of the downloaded drivers and install.
May 19, 2011 | HP Computers & Internet
Already installed driver from downloading online. cannot find driver printer in the devices and printer option of the control panel. cannot find driver when i started printing...
If you have not previously installed your printer or you did an uninstall before downloading the new driver, you now need to add the printer using the new driver.
In Windows 7, click on Devices and Printers.
At the top of the window you will see Add a device and Add a printer
Click on Add a printer.
Choose either Add a local printer or Add network, wireless or Bluetooth printer.
Follow through the choices and if the install program is not able to find the dowloaded driver, point to the location where your driver was downloaded. If you did not make note of the location you could run a search or download a second time making sure you save the driver to a location you can remember. You can then say Have Disk when asked and then browse to the location you saved the printer driver on your computer
If you have the correct driver for your printer and operating system the printer should complete installation
Dec 22, 2010 | HP PSC 1410 All-In-One InkJet Printer
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Dec 09, 2010 | Edimax PS-3103P (ps-3103p) Print Server
Can't scan a document with my HP Officejet 7410 All-in-one
You need to install the printer driver on your system to be use the printer to scan. Locate the CD that came with the printer lunch the CD and follow the instruction to install the scanner driver. If you can not locate CD, you can download the driver from HP website and run the downloaded driver.
May 09, 2010 | HP OfficeJet 7410 All-In-One InkJet...
IR c3200 lost connegtion to my network
Hi sonny31,
To connect to a printer on a network
Double-click Add Printer to start the Add Printer Wizard, and then click Next.
Click a network printer, or a printer attached to another computer, and then click Next.
Connect to the desired printer using one of the following three methods.
Searching for it in the Active Directory
If you are not logged on to a domain running Active Directory, this method will not be available.
Click Find a printer in the Directory, and then click Next.
If needed, change the default printer location listed in the Location field by clicking the Location Browse button, and then choosing the appropriate location.
Click Find Now.
In the list that appears, click the printer you want to connect to, and then click OK.
Typing the printer name or browsing for it
Click Connect to this printer, or click Next to browse for a printer.
Do one of the following:
• Type the printer name using the following format, and then click Next:
• Browse for it on the network by clicking Next, locating the printer in Shared printers, and then clicking Next.
And Thanks.
Mar 05, 2010 | Office Equipment & Supplies
How do i install my mp180 printer without a cd.
You can download the printer software from this link , just select the operating system that your computer is using
Sep 27, 2009 | Office Equipment & Supplies
Show location and how to access cartridges on dell printers
go to page 49 of the manual ("" if you don't have it) good luck!
Feb 22, 2009 | Dell 924 All-in-One InkJet Printer
Unable to locate printer
Also check that:
1. It is the DEFAULT printer in the computer you are using
2. Load driver again from the manufacturer's CD and not the WIndows driver.
3. Check your USB cable and consider trying a differnt cable also.
Feb 28, 2008 | Computers & Internet
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
