Question about Craig CD Shelf System with AM/FM Stereo Radio CM402 Shelf System
Craig Model CM402 "Shelf" CD player w/ AM/Fm
The open/close latch does not hold the top down.  It's supposed to hold it closed on one push and release on the second push.  Is that repairable or do I need a replcement part?
I recently moved and the unit was packed securly in a box.  The problem occured when I unpacked and attempted to use it.  Since it was relatively secure in the box, I do not believe that the latch was damaged but obviously, it doesn't work.
Any help (parts list?) would be appreciated.
Don Goodwill
quantm@localnet.com
  • quantm Oct 25, 2007
    Unit: Craig Model CM402
2 Suggested Answers
SOURCE:
gwcoan
  • 49 Answers
SOURCE: need the remote control for
Here is the link to the web page for Craig Electronics. The picture you will see is of the model you indicated and there is a contact number for Craig in the lower right corner of the screen. I am sure Craig will have replacements for the remote to your unit.
http://www.craigelectronics.com/site/pdetails.php?id=155
Posted on Oct 31, 2010
Boot Lid on my Renault Clio 2005 model wont close
Check you have not accidentally closed the latch this can be done by pushing the lock key when boot is open.
Try to fix by pressing the open key or try to push the latch open with your finger or a screw driver.
Regards Craig
Feb 13, 2018 | Renault Cars & Trucks
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Need the remote control for Craig CM402 home stereo system with CD player and AM/FM stereo radio
Oct 31, 2010 | Craig CD Shelf System with AM/FM Stereo...
How to get the model CR41470B off of military time?
Timber Wolf Press and Hold the ADJ button 12 H will appear on the screen Wait for it to dissapear That's it...
Oct 18, 2010 | Craig CD Shelf System with AM/FM Stereo...
Cover will not not hold closed. Mo. cm402
is it new? take it back. if it's too late for that then take it apart. this is not a problem anyone can help you with
Sep 07, 2010 | Craig CD Shelf System with AM/FM Stereo...
I accidentally pulled the interior trunk release of 2008 volkswag
Try a screw driver,and release the trunk release at the same time and unsnap the latch,the latch thinks it is closed,because the latch never opened back up to allow the striker to go in it and trigger the latch to close,the latch is in closed mode,you will have to manually unlatch the latch sort of speak.
Apr 21, 2010 | 2008 Volkswagen Jetta
2007 Mini Cooper Convertible top doesn't open all the way when I push the button.
The top down function is a two step process...1- hold button until sunroof is all the way open then release button. 2- Press and hold button again until top goes all the way down.
If you try this and it still doesn't work , note the light on the button. If it's flashing it indicates a fault... most likely an obstruction. Check that latches on rear cargo shelf are firmly latched. Check that parcel shelf is firmly down. (open and firmly close all three of these things and try again)
cheers
Feb 20, 2010 | 2007 Mini Cooper S Convertible
Will cursing help open the cd player- if not can you help me figure it out along the line how do you preset the 20 fm stations
turn the power off hold down the cd open close button switch power on if that doesn't work its busted
Nov 05, 2009 | Teac DC-D2831 CD Shelf System
Memorex CD Clock Radio # 2863. Broken latch .. will not hold down top cover
Also have the same problem, clock sat on the night stand for a couple of years. Wife took into work to play CD's at the Christmas Party and the latch failed.
Think we may have used it once or twice as a CD player.
The black latch was easy to remove, justed open up the radio and pushed in the ears on the latch and it slipped back up into the CD compartment.
Will see if I can find something to repair it. Looked like the side cracked and a housing lost some of its side.
Feb 10, 2008 | Memorex AM/FM Clock Radio with CD Player
163 people viewed this question
Top Craig Audio Players & Recorders Experts
MsIslander
Level 1 Expert
Gyula Lacz
 Grubhead
Grubhead
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
