Nokia 3600 slide Cellular Phone Logo
Posted on Jun 05, 2009
My cell phone nokia3600 was eddicted by virus i would like to format my phone memory so please ensure me the code serial number
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
246
Points
6
FACEBOOK SIS HOWA LI FIH HAD VIRUS
what cellphone you use? its is n70>>>
try this!!!
First Method
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key
3) Turn the phone on
Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Backup your contacts list and personal files present in your MMC memory card to your system (if possible).
Second Method
on the screen of your mobile type *#7370#
you will be prompted for a Security Code.
This is 12345 by default if you haven't changed it.
Please ensure that you have backed up your data first onto a PC by using pc suite, or onto a memory card.
Soft Reset
The reset will restore all the phone's settings to factory default.
*#7370#
Hard Reset
Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory.
  1. Switch off the phone.
  2. Press CALL/Send button + * button + 3 button and then ON simultaneously until the phone is completely started.
note: The default password is 12345. You need to press and hold the key until the number appear.
Soft Format for Nokia Symbian Series 60 Phones:
The soft-format code for Series 60 phones is *#7370# . You enter this code as you would enter a phone number in the Phone application. It performs a format of the Internal drive - All data will be lost if you use this feature and your set will be like a fresh phone.
Hard-Format for Nokia Symbian Series 60 Phones:
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
Method 1: Use the following code
*#7780#
note: before u do this make sure u dont have mmc cuz if you have the virus will b tranzfer at ur mmc or memmory card!!!
try the hard format
this is
-green dial key
-the star key(*)
-the number 3 key
if the memmory have a virus just format at pc...
100% working!!! i try that many times
Unoccassional restarts on nokia 5800
Format your mobile code is *#7370#
before performing that please back up and scan your memory card for viruses and try to use once your mobile without your mmc you can come to know chances of virus
44helpful
7answers
HOW TO REMOVE VIRUS FROM NOKIA X2-01 PHONE MEMORY
best thing is to format your phone and memory card.....press *#7370# or *#7780# and give code 12345 or any it will restore. for formatting memory card go to memory card dont open it click on options and use format memory card option(as there is problem of data loss scan first your memory card if no virus is there dont format)
Oct 24, 2011 • Cell Phones
2answers
HI MY NOKIA N70 IS NOT SENDING MESSAGES.WHEN I SEND THE MESSAGES TO ANY NUM IT GOES INTO THE OUTBOX GIVE THE MSG OF ''FAILED'' BUT IS RECEIVING THE MESSAGES
usual cases like this, the mobile is infected by a virus.
* first scan you memory card (use a card reader)to the pc with an updated anti-virus and delete the virus if there is.
* install a mobile S60 anti-virus application for your phone virus security.
(don't insert your memory card on you mobile cause it might be infected again when you insert it again ).
*reset or format your memory card by using this code *#7370# , a lock code will appear and enter 12345 (this is the default code) if you didn't change the code before,or enter the desire code if you've change it before,then wait until the phone reboot.
* you may insert your card now and enjoy using it....
1helpful
I've download a clip and after i had a virus.What should i do to clear it
Hi, Actually you can remove the virus itself, what should you do copy the phone your personal data, image, sound, video and contact number, Save into a memory card. Do hard format to your phone, how to hard format code, type * # 7370 #. enter access code, std code by nokia is 12345. wait until you restart the phone. Now what to do, you should copy all the data you copy into memory before your PC, including contact forlder. Format memory card using your PC, re-enter data previously copied to the memory card with the folder. Put the memory card trsebut to your phone, copy all the contact number in the memory card to phone memory. Your phone is now fully functional. You just need to re-enter other applications such as games and other applications.
I forgot the security code..
Please download the system tool software from below website
http://gallery.mobile9.com/f/1118850/
Install it to your phone memory(DONOT install in memory card)
Then open it, you will have a option called as Format phone.
Select that it wil ask for confirmation ,confirm it ,it will format you phone.
(Note: Remove memory car before formatting)
Thanx
Jul 23, 2010 • Nokia 6600
My phone is taking more time to open any application
Your phone most probably has a virus. You probably got it when you transferred any songs or multimedia application by bluetooth. You have to get it formatted to remove the virus. If you have a memory card get that also formatted to ensure virus proof.
5helpful
2answers
Nokia N70 automatically send messages which displays in outbox folder. It automatically takes number from my contact list & start sending message to that number whether their number is landline or...
Your phone is infected with HatiHati.A malware. It is a worm-like application that spreads via MMC cards. Once the worm copies itself to a new device, it starts sending SMS messages on its own. Here's the DIY cure:
Note: This will erase all data stored on your memory card and phone. Copy contacts from phone to SIM card. Make sure the battery is fully-charged before proceeding.
  1. Format your memory card.
  2. Navigate MENU > TOOLS > MEMORY.
  3. On the memory card menu press OPTIONS.
  4. Scroll to Format memory card.
  5. Once the formatting is complete, remove the memory card.
  6. On your phone dial *#7370#.
  7. Press Yes then enter your phone lock code. Default code is 12345.
  8. When the phone restarts, insert memory card the format it again.
Please let me know if you need further advice.
3helpful
Format nokia 6233
Your Phone does not have any kind of mobile virus (only PC virus are able to store themselves in 6233's phone/card storage).. So either format ur memory card and phone memory (by dialling *#7370# on main screen) or scan ur phone's/card's Memory (in "Mass Storage" Mode) via any PC anti-virus Scanner..
this will be helpful
pls vote for me
20helpful
5answers
Hang and restart
how to be format nokia 3110c
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
