Question about Fuji FinePix A605 Digital Camera
Memory Card What is the biggest memory card you can put in this camera, as the 1GB doesn't work and neither does the 512MB please help!
  • Anonymous Jul 08, 2008
    What memory card should I use with the A605? At present I am stuck with the original 16mb...not good!
    Sergeant:
  • 274 Answers
Your answer is here:
http://www.fujifilm.co.uk/consumer/digital/digital-memory-cards/memory-cards-by-camera?groups=digital-memory-cards&camera_filter=402
Check your manual you may have to format the card.
Posted on Oct 25, 2007
Every time I put in a new memory card (this time I put in a 2gb Sandisk memory card) in this camera it always shuts off and I have to take out the batteries to get it working? What's wrong and what should...
My 33LF had the same problem with a 1gb Memory Card. I have replaced it with a 512mb card and it seems to be working perfectly. I was told that the capacity of the 1gb card exceeds the capacity of the camera.
Dec 09, 2010 | Pentax Optio 33LF Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
I put in a Compact Flash Card and format with camera and I get a message that it tells me out of memory
I HAD THE SAME PROBLEM. FOUND OUT THAT THE CAMERA WILL NOT WORK WITH A 4GB COMPACTFLASH CARD. APPARENTLY IT CANNOT RECOGNIZE THAT MUCH MEMORY, SO IT SAYS IT HAS NONE. I PUT A 1GB CARD IN IT AND IT READS IT FINE. THESE CAMERAS WERE INTENDED FOR USE WITH A 1GB OR LOWER CARD. (HARD TO FIND IN STORES, BUT LOT'S ONLINE.) THE INSTRUCTION MANUAL SPECS 512MB OR 1GB CARDS.
Jun 24, 2010 | Nikon Coolpix 5700 Digital Camera
"OUT OF MEMORY" Error Message
Have you used formatted cards? It may be that due to the incorrect memory card - the camera defualt memory has changed to the camera - Can you check the settings?
May 11, 2009 | Nikon COOLPIX 5100 Digital Camera
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
New Memory Card
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb card is not compatible.
The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Jan 01, 2009 | Olympus Camedia C-350 Digital Camera
Memory card
try a 512mb because your camera could be older then the 1 and 2gb memory cards can handle...or depending on where you are..you could take it to Best buy and they could tell you...hope it helped =)
Oct 23, 2008 | Gateway DC-T50 Digital Camera
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
SD card
wahoo!just been rummaging the internet and i have found that these cameras will only take up to a 1gb memory card!so just get a smaller size card
The camera has 16 MB of internal memory. Memory capacity can be expanded with 16MB, 32MB, 64MB, 128MB, 256MB, 512MB up to a maximum of 1 GB SD or MMC cards.
Hope it helps!!!
Jun 23, 2008 | Kodak EasyShare C330 Digital Camera
Memory card problems
C-Series : Optical zoom lens cameras with sliding lens cover Product name xD-Picture Card *1-7 SmartMedia
3V(3.3V) CompactFlash Type M+ / M Type H Standard C-990ZS - - - X
2MB - 128MB - C-990 ZOOM - - - X
2MB - 128MB - C-960 ZOOM - - - X
2MB - 128MB - C-920 ZOOM - - - X
2MB - 128MB - C-900 ZOOM - - - X
2MB - 32MB - C-500 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-480 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-470 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-460 ZOOM X
256MB - 1GB X
256MB - 2GB X
16MB - 512MB - - C-450 ZOOM X
256MB - 512MB X
256MB - 512MB X
16MB - 512MB - -
http://www.olympusimage.com.sg/pr/notice/1176786_707.html
check up at this website
Sep 22, 2007 | Olympus Camedia C-450 Zoom Digital Camera
Fuji FinePix A605 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
