Question about Zenith SY2751Y TV
Mitsubishi ck3526r A friend gave me this tv and I can not add channels. When I go to memorize channels to add them it doesn't work. So I have this huge tv screen with channels 2,3,4 and 6. I have the original remote but my son messed with it yesterday and whatever he did "erased" the channels. Help!!!
  • 2 more comments
  • nicnic7291 Oct 26, 2007
    I have tried erasing and re-adding but that has not worked either, it is driving me nuts, I don't understand what the problem is. Even when I route through my DVD player it will not go past channel 22.
  • nicnic7291 Oct 27, 2007
    now channels 2-45 are all the bravo channel and 46-75 are what they are supposed to be and I can't even make the DVD player work. I am beyond tears at this point and i give up I am going to tell my friends to come back and get the tv cuz i simply can not figure out why the tv is acting so crazy. its definitely getting signal from the cable co the tv is just messed up for some reason
    I know how hard you must be trying to make me understand what you are saying and I did find the yellow/red/white cords but I still cant make it work. You don't need to waste anymore time with me, I am just not able to fix things like this because i don't understand technology very well. I'm sorry I have wasted your time. Thank you so much for trying to help me
  • nicnic7291 Nov 10, 2007
    Hey thought I let you know I got an old VCR out of the closet and the TV works fine with the VCR you were exactly right about the TV tuner!! Thank you so much!!!!!
    Genius:
  • 1,694 Answers
I feel your frustration! Most all tv's share similar features,but
access varies with mfr & age.Some sets have an individual channel add and erase system as well as an auto-program
method.Others offer only one way to memorize.In your case,
analyze how to erase channels and thus learn to memorize!
If you need more help,please let me know in exact detail the steps you are taking......T.
Posted on Oct 25, 2007
  • 1 more comment
  • Vista Electronics Oct 27, 2007
    The more you tell me,the more I can try to help!
    DVD / VCR will go above 22 if you program it.Before you
    auto-program, select cable.Please read the manual for VCR
    channel programming......If it doesn't make sense,tell me the
    make & model of the DVD / VCR.........T.
    The tv tuner is defective---do not use! Put tv on video input and
    leave it there! Select VCR tuner and use it for channel change.
    Hook-up yellow/red/white out of DVD/VCR into back of TV......
    One last time---leave tv on video input!
    Please rate this situation solved!
    PS. The tv tuner can be replaced, if available.
    Could you rate me thanks for trying??......T.
SOURCE:
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Cannot get picture or sound but can get menu screen wont select or memorize channels on cable
this TV will not tune modern cable signals. You must use a set-top box with a TV that is this old.
Feb 14, 2015 | Mitsubishi VS-8087 80" Rear Projection...
I have a digistar tk1337dr. I keep losing channels which we're coming through my cable connection before. I try to add channels back using the remote but with no results. No channel just snow. Any...
Just do an auto-tune to this TV, and check. All the available channels must be memorized by the TV. If it do not memorize; the main system control memory IC to it is faulty; and should be replaced. If this is the case, contact any service technician. Gopakumar Gopalan Google
Jan 07, 2015 | Televison & Video
Not all channels memorized during setup
YOU WILL HAVE TO PUT IT IN THE CABLE MODE BEFORE AUTOPROGRAMMING. IT IS IN THE MENU RIGHT BEFORE AUTO PROGRAM
Aug 17, 2009 | Toshiba 23HLV87 23 in. LCD Television
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Jan 17, 2009 | Mitsubishi CS-31505* TV
Televison & Video Logo
381 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
