Question about Estate EED4300SQ Dryer
EED4400sq0 DRYER The dryer is not getting hot - it is warm but not hot enough to dry the clothes. I bought it last year...any ideas
  • 833 Answers
A couple of things might be involved. First, be sure that the outlet for the dryer is not clogged. Lint can accumulate in the outlet area. Also check for a kinked exhaust hose and jammed weather door.
Next, reset your circuit breakers (off then on) and check the wiring from them to the unit. If not these things, you have a problem with a blown element or bad thermostat.
Posted on Dec 21, 2007
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
We have a Kenmore 400 dryer. It gets warm but will not get hot--it is only one year old --what should we check for?
there are 2 thin coil wires that have current flowing threw it. it gets red hot and provides the heat to dry clothing, if one of these wires brake your dryer wont get so hot. very common its made cheaper all the time so it wont last.
Sep 24, 2010 | Kenmore 62622 Electric Dryer
I have a whirlpool duet dryer bought it in 2003 from best buy. just recently clothes are not drying completely before shutting off. i hear the gas kick on the heat ..i've stopped it to make sure the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 13, 2010 | Dryers
My GE dryer DBXR463 electric dryer doesn't dry the clothes all the way anymore? What could be the problem? I have cleaned all of the lint and checked the venting on the back. It used to worked fine for...
Check the entire vent (exhaust ) system start the dryer and go outside to the exhaust vent ,you should feel a good amount of warm airflow.bet you will fine low airflow. You need good air circulation to help remove the moisture from the clothing warm or hot temps alone would take longer if ever to dry ..this generally happens slowly over time and the next thing you realize is that its running much longer than it use to... plus it cost more....if you still have a concern you may have a thermostat that is short cycling not letting it get hot enough long enough... Hope this helps GOOD LUCK
Aug 21, 2010 | GE DBXR463EBWW Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Gets warm but not hot enough.
Occaisionally this is due to either dryer being set to a 'delicate' or 'low' setting. Most frequently it's due to an obstruction in airflow so the heating coil is cycling off to prevent overheating. The vent at the back of your dryer should be cleaned out (by sucking out the lint with a vacumn hose) at least once a year. The vent pipe out of your house as well. Make sure that the flap on the outside of your house is opening and allowing free air circulation when the dryer is on. And make sure you clean your lint trap every time you use the dryer.
May 03, 2009 | Dryers
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Oct 11, 2007 | Roper REX4634KQ Electric Dryer
Estate EED4300SQ Dryer Logo
153 people viewed this question
Top Estate Dryers Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Mike
Are you an Estate Dryer Expert? Answer questions, earn points and help others
