FixYa.com
Tags:
Fuji FinePix F30 Digital Camera
Camera shutter button does not work (by 5 users)
posted by sozzy on Oct 25, 2007
I own a fuji finepix f30 and it was knocked off a table.It landed on the top right-hand corner and as a result there is a slight dent. It seems as if the dent has knocked the shutter botton out of place so that it does not function. I can look at pictures i have taken before-the screen still works etc etc but the shutter button does not so i am a stuck with a completly useless camera!!!
I need to get the camera fixed asap- do you think this is a difficult thing to fix? Is it advisable to send it back to fuji or do you think i can get it repaired quickly in a local repair shop? If so, can you reccomend any good repair shops in central london?
Comment by sozzy, posted on Oct 26, 2007
thankyou its nice to know I could get .help online so quickly. Its a really great service and i will reccomend the website!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by kkkyak, posted on Aug 11, 2008
I cannot find the solution you provide for Sozzy, and think mine may be the same solution. How do I access your solution?
Our Fuji finepix f 31fd camera was actually dropped in the Dordogne (briefly)in its case, which offered a little protecton. My daughter tried it out immediately and it took a perfect picture, but a few minutes later it's lens steamed up as we expected, and the shutter simply wouldn't press. Amazingly it has all dried out perfectly, and all the options seem to work apart from the shutter button and it says there is "no image". A hand /stop symbol has sometimes appeared on the screen. Everything else works perfectly. Can we fix it?
Comment by photoferg, posted on Jun 27, 2008
Wow the cable was not visibly loose but after nearly two months (most of it being sad my camera was dead and the rest of it waiting for the special screwdriver) I pushed the cable even though it seemed fine and PRESTO the camera works!! THANK YOU FIXYA!!!
Comment by bforbelinda, posted on Jun 24, 2008
I had the same problem, one day the shutter wouldn't work. I followed the instructions below but was slightly confused that there wasn't a ribbon cable coming directly from the shutter to the main board. The ribbon for the shutter looks like it comes down from the setting wheel (where you choose the manual/ auto settings etc). It is the most right hand ribon. But once found followed the instructions below and pushed it in further and hey presto fixed!!!
So happy I don't have to send it away!
Comment by jermanthei, posted on Mar 25, 2008
My daughter dropped our f30 from our 2nd story loft onto our hardwood main floor and it would not turn on. When I opened it up, I thought all was lost, but like solution #3, which I read here, I found that the upper right ribbon cable had come loose, although I missed this at first glance. After reconnecting it, the camera works fine. Thanks for the help
Best Solution
posted on Jan 11, 2008
FixYa! (100)
astralbee
Rank:Apprentice Apprentice
Rating: 100%, 4 votes
I had a very similar problem, only it was the power button that would not work. The camera would go into playback mode but would not switch on to take photographs. I followed Solution #2's advice - bought a trigram screwdriver (99cents / 50 pence from dealextreme.com), opened the case and there are two ribbon cables that connect the buttons on the top to the circuit board. They must jolt out really easily. I saw that one was slightly out, pushed it back in and now the camera works again. :)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 05, 2008
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
My Shutter button would not work on a FX-F30 Fuji camera. Found this solution here and it worked!
opened the case and there are two ribbon cables that connect the buttons on the top to the circuit board. The right cable was not all the way in on the right side. Pushed it back in and now the camera works.
Thanks FixYa!
Solution #3
posted on Dec 24, 2007
FixYa! (100)
p88l
Rating: 97%, 5 votes
I also dropped my Fuji F30.
The half-press of the shutter didn't work anymore.
I bought a triwing / triblade screwdriver (about 5 euros) to open the case.
The flatcable running from the knobs on top of the F30 to the main print was a bit loose. After reconnecting it, the shutter button was fully functional again.
It seems that from the backside the rightmost 3 three wires in the flatcable are for the shutter, so if your cable is also a bit loose, this might solve the problem.
Solution #4
posted on Oct 25, 2007
FixYa! (100)
MrJLH
Rank:Wiz Wiz
Rating: 83%, 405 votes
1. A local shop will most likely send it out or order a new camera case.
2. It is best you send it to an "authorized" Fuji repair shop.
3. I don't know of any local shops.
4. Here is their customer service link:
http://www.fujifilm.co.uk/consumer/service-support
Rating Locked! (?) sozzy has rated this solution as FixYa!
Solution #5
posted on Oct 29, 2007
Not Rated (0)
johnniebravo
Rating: 0%, 0 votes
the only repair center in florida wants $106.00 just to look at it. any bewtter solutions for a camera I can buy NEW for $180.00??
john
904 334 5730
Can you Help with these Digital Cameras problems?
connecting to mac os x 10.5.4...
hello i am trying to find a... Answer This...
outter case
i dropped my f30 the other day,... Answer This...
CARD ERROR
Hi there I have a problem with... Answer This...
screen cracked... is it worth...
Camera was in pocket when it... Answer This...
white screen of death?
someone took a photo of me and... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
