Question about Fellowes P600C-2 Shredder
Fellowes P600C-2 Motor runs in reverse, but not forward
The motor/gears seem to be working fine, there are no jams in this shredder.
I cannot get it to accept a piece of paper to be shredded.
Help!
  • 2 more comments
  • hannahs Jan 02, 2008
    my motor also runs fine, until I put paper in. it then starts turning for a second and then stops, but the motor keeps going. I've alternated to reverse and the same thing happens.
  • JMKinc Apr 02, 2009
    The P600C-2 Shredder runs in reveerse but not forward. Any help?
  • Anonymous Mar 15, 2014
    WILL NOT GO FORWARD BUT WILL REVERSE, HAVE EMPTIED BASKET
  • Anonymous Mar 26, 2014
    the shredder will not shred paper the reverse works but the forward button is not working. the anti jam light is on.
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Posted on Dec 07, 2007
Take it apart and clean the switch with compressed air.
Be careful when you put it back together that you don't allow the wires to touch the fan.
You also have to make certain that the small plastic teeth that seperate when you feed paper are aligned properly.
Good Luck
Posted on Apr 04, 2009
We have a p600c-2 shredder and it will go in reverse, but it wont work in forwards. we have taken it apart, and we think the problem is the little switch inside. please help?
I had the same problem with my shredder. I removed 6 screws and the cover of the on/off switch. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism so it operated freely and reassembled the shredder. Hopefully this will work for you also.
Dec 04, 2010 | Fellowes P600C-2 Shredder
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
My Fellowes p600c-2 shredder will only run in reverse. I've blown compressed air on the switch and pushed on it with a toothpick but neither method worked. I removed 6 screws and the cover of the on/off...
Never mind providing help, I fixed it myself. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Jan 17, 2010 | Fellowes P600C-2 Shredder
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
Durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 19, 2009 | Fellowes PS60C-2 Shredder
Missing wastebasket to Fellowes Shredder
I have a P600C-2 wastebasket - and the unit only runs in reverse. We need to put our two pieces together!
Mar 08, 2009 | Fellowes P600C-2 Shredder
Motor runs blades not turn
Sorry about that, there is no gears for that machnie. Have a great day!
May 08, 2008 | Fellowes 3011001 Shredder
Shredder no longer runs
Fellowes Customer Service is the best in the business call them at 1-800-945-4545
Dec 06, 2007 | Fellowes P600C-2 Shredder
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
Fellowes P600C-2 Shredder Logo
808 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
