Question about Acer AL1916W 19" LCD Monitor
Flickers i bought the monitor a month back and it flickers i adjusted the refresh rate also but of no use please help when  i contacted the dealer he said it might be to grounding is it true please help
    Problem Solver:
  • 6 Answers
How about more higher rate for that then confirm the cable or any unusual soudn from the monitor?
Posted on Oct 25, 2007
Screen is flickering constantly and goes black after a while
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments. As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting. If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate. If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet Hope this helps.
Jan 17, 2013 | Dell Inspiron 1501 PC Notebook
Tip
How to adjust or change a monitor's refresh rate.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated.<br /> <br /> Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate.<br /> <br /> If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.<br /><br /> <b><u>How to adjust the refresh rate</u></b><br /> Firstly you will need to right click on your desktop background and select <b>Properties</b>.<br /> <img src="slasher_x_72.JPG" /> <br /> This will display the <b>Display Properties</b> window as show below.<br /> <img src="slasher_x_73.jpg" /> <br /> You will need to click the <b>Settings</b> tab.<br /> <img src="slasher_x_74.JPG" /> <br /> Once in the <b>Settings</b> tab you will need to click on the <b>Advanced</b> button.<br /> <img src="slasher_x_75.JPG" /> <br /> Then click on the <b>Monitor</b> tab.<br /> <img src="slasher_x_76.JPG" /> <br /> Here you can change the screen's refresh rate. Make sure the box next to <b>Hide modes that this monitor cannot display</b> is ticked. After you have selected the refresh rate you wish click <b>OK</b>. It would be a very good idea if you have the user's manual for the monitor handy just so that you can see what the manufacturer suggests the refresh rate should be set to.
on May 31, 2011 | Computers & Internet
Get this flsh out of my monitor.
Hi there.
If the screen flickers, make sure the display settings in Windows match the native resolution and refresh rate for the monitor. You can find the native resolution of a flat panel display in the specifications, in the printed material or on the box that came with the monitor. Some common native resolutions are 800 x 600, 1024 x 768, 1920 x 1080, and 1680 x 1050.
The most common refresh rate for LCD monitors is 60 Hz. This normally cannot be changed for flat panel displays using Plug and Play settings. However, if you are using special video software to increase or decrease the refresh rate, change the refresh rate to match the default refresh rate specification of the monitor.
STEP 1
To change the screen resolution and refresh rate settings in Windows, do the following:
- In Windows XP
See my tip on setting up the optimum screen resolution for Windows XP here.
- In Windows Vista (Same for Windows 7)
1. Click Start, and then click Control Panel .
2. Find the Appearance and Personalization area, and click Adjust Screen Resolution .
3. Move the slider bar until the screen resolution matches the native resolution.
4. Click Advanced settings, and then click the Monitor tab.
5. Select the Screen refresh rate that matches the default rate for your monitor (if it is not already selected).
6. Click OK, and then click OK again.
If you cannot select the native resolution or the native resolution is unavailable, continue to the next step to update the drivers for the graphics adapter on the computer.
You can get the latest updated video drivers from the video hardware manufacturer's Web site. Here is a list showing some of the video hardware websites:
Check for NVIDIA video driver updates at NVIDIA Home Page.
Check for ATI/AMD video driver updates at ATI/AMD Home Page.
Check for Intel video support and downloads, Intel Downloads. (If you have an Intel mainboard and are using onboard graphics).
NOTE: If you are using onboard graphics with a mainboard that is not manufactured by Intel, just give me the name and model number of your mainboard and I can try and locate the graphics drivers for you.
After updating the video drivers, go back to Step 1 and try to change the screen resolution again.
Note: If you cannot select the native resolution after updating the video drivers, the graphics adapter in the computer might not support that resolution and may need to be upgraded.
If after changing the resolution and updating video drivers the flickering persists then check the video cable connections. Unplug the cable and inspect the cable for damage. If the cable is damaged, replace it with a new cable. Try to use cables less than 3 meters (10 feet) long.
Monitors are sensitive to magnetic fields so have a look at the environment around the monitor. Speakers, florescent lights, fans, cell phones, radios, and any other electrical device can cause flickering. Temporarily move electrical items away from the monitor to see if they is producing a field that causes the flicker.
If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, then this means that the graphics adapter hardware on the first computer is damaged or might need to be upgraded to use the monitor. On the bright side at least it's not your monitor.
If however the flicker remains then the problem lies within the hardware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchase and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
~Slasher_X
Oct 30, 2011 | Philips 190B6CB/27 19" LCD
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
MY MONITOR MODEL IS LG FLATRON T705SH I CANNOT ADJUST MY SCREEN RESOLUTION I WANT TO KNOW THE VALUES SUCH AS POSITION: SIZE: SHAPE: PLEASE HELP ME OUT SIR AS SOON AS POSSIBLE
Your monitor supports a maximum resolution of 1280 x 1024. If windows fails to give you the option of changing to this resolution and those below it then please follow these suggestions:
Update your video card drivers, if you don't know the manufacturer of your video card try windows update.
Install the latest drivers for your monitor as well.
Your monitors driver click HERE
May 04, 2011 | LG Flatron F700B 17" CRT Monitor
My screen flickers horribly...its been just 7 months i have bought this lappy....and i initially encountered this problem a month ago...it was just a line that time so i didnt take it seriously....now the...
Check the monitor refresh rate. For Vista - Right mouse click on the desktop... select properties... advanced... Monitor. Try a different screen refresh rate if available. Do not change to a refresh rate not supported by your monitor as this creates more issues.
Chappo07
Sep 21, 2010 | Computers & Internet
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Flickers
I assume it is an LCD monitor, sounds like you have bad lamp or a lamp power supply. It also could be wrong refresh rate for the monitor, try changing the refresh rate on your computer.
Dec 19, 2009 | SVA-USA Computers & Internet
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Acer AL1916W 19" LCD Monitor Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
