To use the Acer recovery CD you need to boot up with the CD. Go into the BIOS setting and scroll through the settings until you come to Boot order. Then move the CD/DVD drive up as the first boot device and the hard disk as the 2nd boot device. When you boot up the Acer with the recovery CD in the CD/DVD drive then it will boot up with the Recovery CD.
have you change the settings of boot device from your bios?..in order for you to boot from CD or DVD once you install a windows, first go to your bios settings and change the boot device priority. The 1st boot should be the CD/DVD. Hope it helps thanks.
Go into the BIOS and change the boot startup device order. Make the CD the first boot device and the hard disk the second boot device. If you do not wish to change the BIOS you may select the CD drive as an alternate boot device by pressing F10 or F!2 as the laptop boots up to bring up a list of devices to want to boot from, select the CD drive and the follow the screen prompt.
There are a few things you can try . First , try this : the computer is off . Turn it on and Press F1 key repeatedly or whichever key applies to your computer that enables you to access your BIOS settings . Then , using the arrows you will select boot options or boot settings . Then , you want to arrange the boot order device sequence so the CD is first. Some computers display a boot device options when you first and computer on by pressing a special key, like ESC or F12. You want the computer to boot from the CD ROM with your XP disk in the drive. This should allow you to properly format the HDD and install XP. If that doesn't work , check your BIOS settings and select the default configuration , then be sure to exit using the exit dialogue box and select exit saving changes and then yes when prompted . Then, do the device boot options thing one more time with the CD as the first boot device .
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
