One minute its working the next its completely dead. Its been working ok for the last few years.
SOURCE: sm58 beta is totally dead
Hi djmalatesta
One could go all superstitious and suggest that it was just bad luck!! It is unusual for one of these industry standard mics to just stop. The most likely cause is the capsule has gone open circuit. you could check this with the 1k range on a multimeter by unscrewing the wind shield and measuring across the . connections to the capsule. If the capsule measures ok, it may be the wiring to the XLR socket at the base of the mic, the switch getting to there. Either way, it can be fixed. Can you meter out the capsule and report back to me what you found?
I am more than happy to answer any other questions you may have about
it, please get back to me here, or use the ASK function to go straight
to me :) If you are still unsure, have problems, or we need to look at
the situation more deeply, then before you give a rating for this
advice, hit the ASK button
Thanks for using FixYa, If you consider the advice I have given you as
sound, a FixYa rating is a great reward for my efforts to help you.
Cheers.
regards
robotek
SOURCE: ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
SOURCE: Miele WT946i Washer/Dryer - NO LIGHTS!!! MAYBE DEAD :-(
Capacitor first (noise filter) then control board
