Question about Lexmark P315 InkJet Photo Printer
Lexmark P315 InkJet Photo Printer Ink Cartridge Problem
Hi, I would greatly appreciate any help with this.
I have the stated photo printer and it was fine until I changed the ink cartridge. I've changed it before, and it's been fine. But this time, it reads "cartridge error". So i thought it was a faulty cartridge, tried again with a new one, and at times, it says "cartridge error" other times, it says "cartridge not detected".
I'm starting to think it's the printer itself, but it recognises the old, empty cartridge if I put it back in.
I don't know what to do, short of taking it apart or taking it somewhere to be looked at.
Thank you in advance xx
    Scholar:
  • 104 Answers
Hi, I know this might sound really bad but have you made sure that you have taken ALL the little bits of plastic and covers that are sometimes on the new cartidges?
Also are you using the exact same cartridge as before?
Another thing you could do to bypass the problem is to have your one refilled. That will at least fix the problem for the immediate.
Does your printer have some software where you can run a clean print head and do an align and other stuff. If so you could try those too.
Lets us know.
Posted on Oct 28, 2007
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
Hi, im having problems with my printer and any help would be greatly appreciated, i recently replaced the colour cartridge and tried printing photos with a bad result, the colours are not clear and do not...
trying to print a few pages and see if the color change color tone, you should feel an improvement in quality. (probably the Charter will require a new roll until the ink replaces the old print head), unless felt an improvement could be to blame and cartridges must be replaced with good quality
Apr 12, 2011 | HP PSC 1215 All-In-One InkJet Printer
Paper Jam Issue with the HP Deskjet 5440
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
-levibit-
Mar 20, 2009 | HP Deskjet 5440 InkJet Photo Printer
How to move the cartridge to the left to fill in the ink?
Hi-
Press the ink button ( press and release) up until it goes to the position where you can change the ink cartridge.
Hope this helps
Aug 26, 2008 | Epson Stylus Photo R260 InkJet Printer
Lexmark x2480 will not print since i changed ink cartridge
Dude just reinstal the printer and evrything will be fine if not let me know
May 26, 2008 | Lexmark All-in-One Printer, Scanner &...
My lexmark x2480 won't print since i installed new cartridge
try to reinstall programme for it or check the cable between com and printer.
HELP !!!! Instantly empty INK CARTRIDGES Epson Stylus Photo R1800
Hi
What i can recommend is call epson and tell them about this issue and for sure they are going to replace the ink and will run diagnostic test on your printer- here is there support line number 562-276-1300
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Can't use compatible ink
You need a chip-resetting tool.
Or use the printers software utilitie changing ink cartridge, some printers insist that you go into your printer software/program. to inform or communicate with the printer, that you are changing a Cartridge. then the printer, will move the printhead to the desired position, to remove the cartridge.
When the new cartridge is installed, the printer is set to look for new changes. make sure you,ve inserted the cartridge fully into it,s slot ( holder ) push until you get a slight click.
If you,ve disabled Status monitor, then your printer cannot output the Cartridge Status. ( empty-Full )
mike @ Compurepair.
Feb 25, 2008 | Office Equipment & Supplies
Lexmark P315 InkJet Photo Printer Logo
161 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
