Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Freezer Our freezer will not turn off and it only seems to get to a certain coldness and stops eg our ice cream is always soft when before it was rock hard .I tried to switch it to colder but this did not help
  • 114 Answers
Check the back wall of your freezer section to see if it is icing up.  If so, you have an automatic defrost problem.  One or more of your defrost components (timer, defrost heater or bi-metal) has failed.  If there is little or no frost on the back wall, you could have a compressor related issue.  This is often indicative of Frigidaire refrigerators.  If the unit is less than five years old, the compressor is still covered under their warranty.  If it is the compressor and it is more than five years old, start shopping.
Posted on Oct 26, 2007
SOURCE:
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Need freezer setting
start with it in the 'middle' and adjust if needed. I always used ice cream to judge how cold to set my freezer, if it was too soft I turn freezer temp down, too hard I turn it up
Mar 07, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GB2FHDXWB01 just started getting way too cold in the freezer. Ice cream is rock hard, seems to run all the time.
Most likely its the cold control located in the fresh food section...unless you have a dual cold control....
Oct 03, 2012 | Whirlpool Refrigerators
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Ice cream maker doesn't chill
The machine must be upright for 24 hours before using it.
If it was stored on its side or upside down you MUST wait 24 hours with the machine in the correct upright position. The 'person' who delivered mine made sure he tumbled it over and over again scanning shipping labels even though it said everywhere fragile and this side up.
If the machine does not work at cooling after 24 hours there is a problem and it should be returned.
Do not expect rock hard ice cream, but thick scoop-able medium firm soft-serve is easy to get as a result. A few hours in the freezer will harden it more.
Nov 08, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
My ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer seems as if it is not cold enough
Your sensor is packed in ice and giving false reading (always frozen)
You NEED to defrost. Will take 2hr
Turn off or Pull plug on freezer
Take everything out and put in cooler, brown bags, large bin or boxes to stay cold
Defrost by setting large pail of boiling water in each side bottom of freezer and closing door(s) for 1/2hr
Open freezer, empty pails in sink and use pails to hold large chunks of ice from freezer that will come out easily
Toss out ice chunks
Check sensor to be sure it is no longer packed in ice
Wipe down interior dry
close doors
plug in
wait 1/2hr
reload with stuff you want to keep
Done!
Mar 26, 2009 | Refrigerators
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
78 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
