Question about SanDisk Sansa m240 MP3 Player
Stuck on initializing screen
When i plug in to the usb port, the initializing screen wont go away.
when i unlug it the screen flashes same thing (sandisk initializing)
  • 1 more comment
  • daroach7 Nov 11, 2007
    The MP3 player is stuck on initializing screen and my computer will not recognize the device.
  • Anonymous Nov 15, 2007
    stuck at initializing .... can't get pass it ... firmware dead?
  • avalone Nov 16, 2007
    my mom bought me a PINK Sansa m240 runing on firmware update v 4.0.44r & for a time last dec through this last feb it worked & then nothing it just got stuck at the loading screen & i've got music stuck on it, is there a way to downgrade the firmware to make it work
Call Sandisk support. This is a known problem with this model that was sold in December 2006. Apparently later models fixed the issue. They will get your info and do an RMA, and they even provide the UPS shipping label.
They were great to deal with. I hope you have the same success.
Posted on Nov 20, 2007
SOURCE:
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
MY LC60LE745U BIG SCREEN WONT RECOGNIZE MY FLASH STIK
I believe your TV has 2 USB ports on it. If you have equipment connected to the other USB port, that port will get priority and the TV will ignore your flash stick. Turn off your tv, disconnect everything on your USB ports then insert the flash stick. Power on the TV and hopefully you can see the flash stick.
Mar 22, 2014 | Televison & Video
Initalizing usb controller
So what about it?
You get stuck on this when you boot?
You get an error Initializing USB Controller? When you do what?
You want to manually initialize the USB Controller?
You don't say what brand/model PC or OS...
What are your USB devices? Mem Card Reader, Kybd, Mouse, Game Controller, Joy Stick got a button stuck?
Something plugged into a USB port is probably bad. My guess is memory card reader that plugs directly into the mother bd.
Dec 06, 2013 | Computers & Internet
Ipad pluged into outlet the apple just flashes plug into usb port screen flashes black
go to setting look for connection , wireless or network settings. then go to USB connection and choose ask on connection that way when you plug your ipad in either to charge or hook up to the pc it will ask you what you want to do.
Jun 30, 2012 | Apple iPad Tablets & eReaders
Eclipse mp3 player 4g wont charge
Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
May 04, 2012 | Mach Speed Eclipse 180 MP3 Player
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Sony walkman nwz-e438f won't start up
check that your not plugged in to a usb hub, my hub is USB 1. When I connect direct to a USB2 port problem solved!!
Jan 04, 2009 | Sony NWZ-E438F Digital Media Player
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
Transcend JF V30
USB DEVICES THE PROPER WAY ON INSTALLING USB DEVICES A. Enable usb ports on the BIOS. 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 21, 2007 | Electronics - Others
SanDisk Sansa m240 MP3 Player Logo
296 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
