Question about Cameras
Cleaning out dirt and dust inside nikon fg camera
Hi,im a new camera enthusiast...got an old nikon fg camera with some dirt inside ..want it cleaned..is using cloath ok...what sort of cleaning stuff i need..thank you...
alex
  • 37 Answers
FG's are pretty tough old cameras. You can use a cloth and a lenspen brush, but be very careful of the shutter curtain...its delicate and if you damage it you might as well get another FG ($30 or so on Ebay). My first Nikon was an FG-20...still works like new.
Posted on Nov 03, 2007
SOURCE:
My Nikon L35 AF's shutter button won't pop back up when I press it down.
Hi Broderick,
You have some (dirt/ dust/ sand) clogged around the clearance between the shutter button and the camera body. If you are a DIY type of person, you can check and clean that dirt, other wise take it to a repair shop for proper cleaning.
Jan 14, 2016 | Nikon Cameras
I recently bought a Nikon FG, and when i look through the viewfinder all i see is black. I made sure the lens cap it's on, and its still black! I need to replace the batteries, but will that fix the...
Take the lens off the camera and look inside. you should see a mirror angled at 45 degrees. If you do not see the mirrir, it is probably stuck in the up position and repair is necessary
r
Apr 22, 2011 | Nikon FG 35mm SLR Camera
This is an old nikon camera FG. I have put a new battery into the camera and set to what the manual tells me to do. But looking through the viewfinder when I depress the shutter release button non of the...
Hi, see if the batteries or the battery are installed correctly (positive side as the bat. cover shows + sign).
Mesure the voltage = 3 volts.
Look at the battery cover and body contact, and see if there is contact battery leakage;clean if necessary.
Also the counter should be in 1, nothing happens, the counter SW dirty or defective contact.
Other Main PCB bad.
Best reggards
Feb 23, 2011 | Nikon Cameras
My nikon 775 just won't start even after i put in a new battery (i thought it was a battery problem). any clues on what i should do before i retire if permanently?
Hi
The Nikon Coolpix 775 can be powered using a EN-EL1 rechargeable battery or a disposable 2CR5 type battery (Panasonic, Duracell, Maxell etc). If you are trying to use an EN-EL1 you may want to try using a 2CR5 - this would prove if the battery charger you are using to charge the EN-EL1 battery is working correctly.
You can also try and check if the contacts inside the battery compartment are clean - the camera is quite old and there will normally be some dirt deposits after that length of time.
Hope this helps.
David
Jan 13, 2011 | Nikon Coolpix 775 Digital Camera
Spot that shows up in the same spot on all my pictures
It can be a piece of sticky dust or dirt on sensor surface which can't be removed with a blower or canned air. You can try to remove it by yourself with special cleaning swab and cleaning liquid. But this process requires some experience, so the safer way is to bring camera to service center where sensor can be cleaned fast and risk free.
Jul 19, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Whenever I go to use the camera, in all settings, the f stop just flashes and the camera refuses to take the shot. is there a simple solution or do i need to go to specialist repairers? this happens with a...
This usually means your camera is not communicating with the lens properly. Inside the body of the camera - directly above the opening for the lens mount - are 7 square / rectangular pads. These pads are the electrical contact points, that when mated to the corresponding pins of an automatic Nikon (or compatible) lens, provides the signals to set / confirm f-stop, focus, etc.
Since this is occurring on several lenses, unless you're failing to install the lenses fully into the body, the issue probably lies with the camera body itself. There may be an issue with dust, dirt or oxidation on these contacts - or a problem inside the camera - that is interfering with the those signals. You can wipe these contacts with an alcohol prep pad in an attempt to dislodge any dust and dirt. Clean any lenses used on the camera as well - as dust and dirt on the camera contacts means it's probably been transferred to the lenses, too. Oxidation is a bit trickier to tackle - because the camera is wide open to collecting anything that drops into it. If cleaning with an alcohol prep doesn't solve the problem, I'd contact Nikon support for their suggestions or to arrange for repair.
Jun 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Picture come out with black dot inthe middle of the picture
If Alex's comment didn't resolve your problem, check for dust inside the camera body and on the part of the lens that goes into the camera body. The highlight indicator he speaks of will show on the LCD screen, but should not show up on your final picture once downloaded from the camera. Since the optics on that end of the lens are smaller, they are more susceptible to dust and dirt. If there is dirt or dust inside the camera body and you are not familiar with how to clean it, same yourself some headaches and take it to a qualified camera shop. You can seriously damage the interior optics of your camera by attempting to clean it the wrong way.
May 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Dust inside screen of Nikon Coolpix S51c
You won't be able to get it cleaned with canned air. The dust that developed is underneath the screen. I recommend sending it to Nikon or the camera doctor.
http://www.cameradr.com/
He can clean it for you cheaper and faster than Nikon could do it.
Nate
Nov 18, 2008 | Nikon Coolpix S51c Digital Camera
D80 shutter issue
contactjoni,
Your shutter will stick if it gets dirty or dust gets in the camera, a reputable camera shop can inspect the shutter, the sensor for dust & dirt and can clean it for you. If the battery is low while shooting the shutter can also stick on longer exposures.
randy320sgi
Jun 28, 2008 | Nikon D80 Digital Camera with 18-200mm...
Nikon FG suddenly stopped working--not battery problem--help!
you should invest in a digital camera they have nice cameras for like 40 dollars on overstock.com
Mar 18, 2008 | Cameras
Cameras Logo
960 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
