Question about Denon AVR-2106 Receiver
Denon AVR-3000 I've purchased this analog unit in 1994. I get no sound from the right side speaker. I have tried speaker A and B and get same result. I have switched speaker from left to right and get same results. I assume that a channel is blown and the cost to repair may be more than unit is worth. Ant advice? Ted Lovell
If your balance is fine etc., unplug remove 8 screws(sides) 4 screws (back) and remove top cover. Carefully remove large 4" ? black cylinder in front left (4 screws) turn upsidedown and to the side without tugging on wires. that will expose 2 glass fuses on lower board behind it. Check them with a continuity tester and the one on the top board as well.
Posted on Jul 16, 2008
  • 979 Answers
First, check your balance control and make sure that it is centered. Next, you might have anything from a bad output relay or fuse to a bad driver/component...accordianman
Posted on Oct 25, 2007
I have a Denon AVR 2802. No sound output when adjusting master volume knob. When trying to solve the problem, I found out that I can achieve sound output by pressing the CH vol button and adjust individual...
try to reset. Unplug the unit, press and hold speaker A and speaker B buttons and plug the unit in outlet. If doesn't help, the unit may have a problem with microprocessor or dsp boad and need to be serviced at a repair shop.
Oct 04, 2011 | Denon AVR-2802
Denon avr-1804/884, speakers Bose vcs center, Bose acoustimass 5 series 3 speaker system, Bose 201 series 4. All speakers play in test mode, with tuner, dvd, phono, cassette. The left side speakers will...
You don't say how "TV audio" is entering the system.
My guess is you're using analog audio Out from the TV into an analog input on the Denon. One channel failing would probably be the Left Channel cable failing or not seated.
I always recommend bypassing the TV audio entirely if the programming comes from somewhere other than its own antenna, as TV audio electronics add nothing good to the process.
If you're using cable box, sat box, game, whatever, ITS audio is best sent directly to your Denon's specialized audio hardware - digitally, if possible, to preserve multichannel possibilities.
You could also run standard analog audio from the cable box to the TV analog Audio IN if you just want to watch news and weather on TV speakers without the Denon involved.
Jan 11, 2011 | Denon AVR-1804 Receiver
Denon AVR-1908 speaker issue
Before we play taps and throw dirt on top of the Denon, perhaps a bit more triage is in order. I'm not certain who the patient is. Especially when you have "speaker issue" in the title. Are you saying there are some speakers that don't work ONLY with BluRay?
If it has NEVER worked the (unnamed) BD player or its cable(s) could be at fault, too.
What 'connections' are we talking about. HDMI, coaxial- or optical audio, 5.1 analog; to what input on the Denon assigned to what function?
Have you tried all audio paths out of the BD player? Is it configured to squawk in the right digital mode?
Do you have any other digital audio sources (CD/DVD) you could use to certify the audio paths that don't work with the BD player?
Apr 08, 2010 | Denon AVR-1908
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
Denon avr 3000 speaker B is off ,is theres a code to turn it on
I have a Denon AVR-3000 and want to turn on the B Speakers. I have hooked up my subwoofer to the B connections on the Denon since there is not a subwoofer connection. How do I turn the B speakers on without a remote
Jan 27, 2009 | Denon AVR-2106 Receiver
Speakers on the right side of my AVR will produce no sound in any
change the right channel audio ic of your denon amplifier.
Jan 07, 2009 | Denon AVR-1906 Receiver
Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
Dec 20, 2008 | Denon AVR-3803 Receiver
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Denon AVR-2106 Receiver Logo
394 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
