Question about HP Vs17 17" LCD Flat Panel Monitor
Screen goes dim under different user
Have HP vs17 monitor (16000 total hrs, 7000 backlight hrs), screen goes dim whenever I switch to son's user settings.  Other three users on same XP system no problem, just my son's user settings.  Tried to adjust basic diplay settings same for all users, lower brightness/contrast ratios, screen still only dims when son signs in.  Any suggestions?
  • 2 more comments
  • dccjr Oct 25, 2007
    Thanks, but as far as I can tell, resolution/refresh same as other users.  It must be something in his startup because screen is initially OK, but as soon as everything loads screen goes dim, can't see anything unusual on task bar. Also,  if I switch to other users, screen now dim there as well, must restart computer and sign on as user other than my son to get the screen to pop back to normal brightness.
    Any ideas?
    In safe mode, screen brightness same on son's username as other users.  Is there anything specific I should look for in his startup that would cause screen to dim after all programs loaded at startup?  I've tried to find something different in his settings but can't see anything, or maybe I'm not looking in right place.  Also, once everything loads at startup and screen goes dim, if I then switch to another user, those screens are now dim too, and I have to restart, choose another user, starts up then turns back bright.
    Cleaned up the startup section using msconfig, but still can't find any setting unique to son's user that's causing screen to darken only under his setup.  Since monitor works fine with any other user, it's got to be something specific to his user setup, but everything I check seems to be the same for all users. Any other ideas?
  • dccjr Oct 26, 2007
    Thanks for the suggestions, but nothing seems to work.
    I set up a new user account as a test for my son and it seems to work fine. If I just delete his old user account (the one that with the dim screen) and have start using new one will we really be giving up a lot?  Should I continue to try to fix current user account?
  • 38 Answers
Could be an issue of his resolution and refresh rate settings are close to being out of range for the monitor. Try lowering these settings to get better performance.
Posted on Oct 25, 2007
  • 2 more comments
  • Alessandro Fuchs Oct 25, 2007
    Try booting in safe mode
    F8 at startup
    select safe mode
    then login to your sons username
    you could try going to start > run> type msconfig and going to the startup tab and disabling everything
    you might look into any particular software apps he has installed on just his profile that might interfere with the video driver.
  • Alessandro Fuchs Oct 26, 2007
    you know what your absolutely right. If a new user account will fix the problem for you, i say absolutely go for. When your installing thing for his new account just do one thing at a time so you can see if something is having an adverse effect.
Hp 17d monitor black screen
More info? Does monitor turn on any? Have you eliminated backlight from problem? Any LED lights on, if so what color?
Jan 12, 2013 | HP Vs17 17" LCD Flat Panel Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
When I turn my monitor on, the screen shows the desktop momentarily and then goes black. If I turn it off and on a couple more times, the desktop will stay on and function normally. Where is the likely...
Try the monitor on another computer, to check-out the monitor.
Does the POWER lamp on the monitor stay on when the monitor goes black? If so, then the monitor probably is OK.
Try a different monitor, to trouble-shoot the video-card.
May 28, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor comes on for 2 -3 seconds then goes off again
When you say "It comes on" do you mean that: A) The power light comes on B) the screen backlight comes on C) The above 2 happen and you get an OSD D) you get A+ the OSD comes on then you can only see it faintly E) Other please specify.
Jun 07, 2009 | HP Vs17 17" LCD Flat Panel Monitor
I have a HP Pavilion laptop ze4900. Every time I move th screen, the display either goes off completely, or it goes vey dim and I cannot read anything from it. The only thing I can do to get a display
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Computers & Internet
Compaq V2000 Display blacks out
sounds like the backlight has gone....test with an external monitor....if the external monitor works without any problems...the backlight has gone...better to get a professional to do this as its kind of fiddly and involves taking the screen apart
Dec 22, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion ze2000 Monitor is dim
Yes, this is what happens when the backlight goes out.
This will give you an idea of what is involved in replacing the backlight. You can find a replacement backlight here, or on ebay, just take your current backlight(s) out, measure it or them, and buy replacements of the same measurements. It doesn't have to be for the same model laptop as long as the CCFLs (cold cathode florescent lamp) are the same size.
Aug 11, 2008 | Computers & Internet
Fp 7317
My monitors green light stays on, but the screen will come on for a second then goes off
comaq fp737
any ideals
May 15, 2007 | Compaq FP 7317 17" LCD Monitor
Monitor dims for one account, not the other
I would first contact the GF administrator and ask them if they've heard of this before. Then I would contact Acer.
Jan 18, 2007 | Acer AL1916B 19" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
208 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
