Question about Brother MFC-9420CN All-In-One Laser Printer
Brother MFC-9420CN Paper Jam B!!!
Message says "Remove the jammed paper on entrance to the fusing roller"
I have opened the back, removed the paper, Checked everywhere else. But still getting the same message.
Please help.
    Problem Solver:
  • 14 Answers
Open and check for paper in the back. sometimes a corner may have been caught in there and will give you the error.
jb
Posted on Apr 29, 2010
TURN THE PRINTER OFF AND ON. IF THAT DOESNT WORK, UNPLUG THE CORD FROM THE PRINTER, WAIT, THEN PLUG IT BACK IN. TURN ON. OTHERWISE, I DON''T KNOW
Posted on Nov 05, 2007
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
I have a paper jam but the paper is stuck
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 27, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper jam
im assuming you are using regular copy paper, is so fan the paper out before you put it in the printer and also check to see if the roller inside the printer are clean. they pull the paper threw the machine.
Jun 28, 2009 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
alternative :
Jun 03, 2009 | Brother MFC-290C Printer
Paper jam message brother MFC-440CN
Generally theres still a small piece stuck somewhere. Remove the back where the paper feeds through and check there. Then open the top so you can see the ink head and check around there. That should do it. The printer sometimes wont remove the jam until you open that top lid.
Also try switching it on and off again just to be sure.
If it's still there, the only other way is ripping it apart to find that pesky bit of paper still stuck.
Mar 24, 2009 | Brother MultiFunction Center MFC-440CN...
Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
Nov 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
878 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
