Question about Toshiba (SD-W2002) DVD-RAM Burner
Drive bay comes out
Sir,
my drive's bay always comes out when the computer starts ...................it continues for sometime and then stops automatically....................again when any disc is inserterd it shows the similar problem and often gives messages like "device not ready"......................   .Recently;i had removed that drive from the system........please give some solution to fix the drive problem...
    President:
  • 2,961 Answers
Your drives firmware is damaged and needs to be replaced by an updated version otherwise it will have to be replaced if still ejecting at start up.
Posted on Oct 25, 2007
Buzzer sounds at random in 2004 Focus
LOL... the rear hatch needs to be realigned.. try moving the latch catch back a bit so it seals correctly!
Jul 30, 2012 | Ford Focus Cars & Trucks
How to put in sata hdd in an acer aspire X3200
Remove the Power Cord, Remove the Case, sit the laptop on it's side and look for the hard drive in a bay. The drive will have 2 cables going into it, one for the Power coming from the power supply and the other is the SATA Interface Cable that will come from the motherboard. SATA Cables are slim flat cables, most times they are colored red, blue or black. Remove the cables from the hard drive, remove the screws if any are holding it in a bay, sometimes there may be plastic rails that hold the drive in the bay (especially on Dell Computers, most times the rails are green or blue). Sometimes there may be a need to remove the bay to get to the drive. If so there will be a screw or two holding the bay in place.
Once removed, put your new drive in, put all the cables in place then reboot to your Operating System Disk to load windows on it. After windows is loaded check your drivers in the device manager, if any are missing, download and install them. Then start loading you application programs.
Apr 09, 2012 | Acer Computers & Internet
How to put sata hard drive in
Apr 09, 2012 | Computers & Internet
I have almost same problem. This problem start one time when I using my computer. Computer always stop after trying restart, sometimes start normally and stop after few second. And now when I start...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
make sure that your RAM is securely seated
hope this will help
don
Feb 24, 2011 | Abit KV8 Pro Motherboard
Hard disk not found message coming while installing windows server 2003 on HP Proliant ML150 G5 server system.pls help me
Save any critical or important files. Even if this is an secondary hard drive installation.
Turn off the power and unplug the PC from the outlet. Also, unplug all external connections to the Windows PC. Be sure to touch something metal to ground the user. Static electrical shocks can damage a PC.
Open the PC housing and determine the placement of the hard drive. Generally computers come with a latch that, when pressed, opens the housing. Make certain the space necessary for the hard drive is available. Usually the drive bays are in the front of the PC near the CD or DVD drives.
Make sure the IDE jumpers are set correctly. If the hard drive is the primary drive then set the jumpers to "Master" mode. If the hard drive is the secondary drive then set the jumpers to "Slave" mode. Please consult the hard drive's manual for the proper jumper setting for each mode. Another possibility--if there are two hard drive, set both drives to "Cable select" mode and the Windows PC will choose which one to make "Master" and "Slave."
5
Mount the hard drive in the available internal slot. The drive is sometimes mounted with four screws to the drive bay. Some internal drives have a rail that slides into the open bay. Look at the other devices to determine which mounting option is available in the specific computer.
6
Connect the hard drive cables to the Windows PC. Connect the power supply connector to the available cable. Next, connect the data cable to the available connector. The internal data cable usually has a red stripe to make identification easier.
7
Close the housing and reconnect the external power supply. Plug the external cables back into the computer and reconnect to the power supply.
8
Configure the BIOS. The BIOS (Basic Input/Output System) is accessible during computer start-up. To access the BIOS consult the computer manual to find out with which key press during start-up. Most often, the key is F8. Once in the BIOS change the hard drive setting to "Auto detect." When finished, exit the BIOS and allow the start-up to continue.
9
Format and partition the Windows PC hard drive. Select "Start" from the operating system menu. Choose "Control panel" from the start menu. Next click on "Administrative tools". From the administrative tools menu choose the "Computer management" icon and finally "Disk management." Choose the new hard drive and right click. Select "New partition" from the right click menu. Follow the on-screen option to partition and format the drive the drive.
10
Restart the computer and check the hard drive to ensure it is operating properly.
Feb 23, 2011 | HP ProLiant ML150 G5 Server - 1 x Xeon...
Dear sir Its bias is creating problem during start.Some time my pc start booting and sometimes it stop after some time
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 12, 2011 | Foxconn (945G7MA-8KS2) Motherboard
Loud noise from engine bay on start up. it continues when the car is running. the only way to describe it is it sounds like a whosing noise
I don't know what whosing sounds like, but I have a high pitched whirring noise coming from my somewhere in the engine bay, my noise starts when the car starts and continues while driving, goes away at around 60 mph but will come back when I accelerate or decelerate, I have a friend that is a master tech at volkswagen, he suspects the alternator is making the noise, this is my first TDI, I bought it with 150k on it, I don't have any experience with TDI's, but am a Service Advisor, and it has been my general experience that all volkswagens are posessed! :) Always having some sort of electrical issue, Not sure if that will help.... Good Luck!
Mar 18, 2010 | 2000 Volkswagen Jetta TDI
Disk error in starting computer
Please Check You Disk By CHKDSK COmmand in dos
For it Press F8 Key continuously When Computer Started and Select Option Run In DOS MODE!!
VIkas Agrawal
MCA
Feb 09, 2010 | Computers & Internet
Toshiba (SD-W2002) DVD-RAM Burner Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
