Brother PC-210 Computerized Sewing Machine Logo
A
Anonymous Posted on Feb 01, 2014
Fix brother PC-210 E6 error code - Brother PC-210 Computerized Sewing Machine
2 Related Answers
Anonymous
  • Posted on Jul 12, 2010
SOURCE: on a brother cs-600i sewing machine, what does the
what does code E6 mean and how can i fix it?
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on May 31, 2012
SOURCE: brother sq9000 error code e6
the bobbin case may need to be replaced. a sewing machine shop
can tell you for sure
My brother cs-6000i computer sewing machine shows a E6. I cleaned around the bobbin and checked the needle. I replaced the bent needle and it still does the same thing "E6". What will fix this?
Follow the instructions below if you receive the error message "E6"
1. Check if the machine rattles and stops as soon as the sewing starts
- Upper thread could be tangled or threaded incorrectly
- Check that the thread take-up lever is threaded
- Raise the presser foot to raise the needle to its highest position and re-thread the machine
2. Remove the bobbin and bobbin case
- Clean any lint or loose threads
- Install the bobbin case so that the projection on it aligns with the spring and install the bobbin into the bobbin case
3. The needle could be bent
- Check that the needle does not hit the needle plate
- Replace the needle if necessary
- Make sure the flat side is facing the back
If the problem persists, your machine may require service.
If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
https://help.brother-usa.com/app/answers/detail/a_id/54048/~/error-message-e6
I have a Brother XR9500prw, Error code E6 came on the screen. I did top thread again. No tangle so I continue to input numbers for the lettering font. The machine will do nothing. How do I fix this?
Q: What does E6 error message mean? A: The motor locked up because thread is tangled Q: How to fix E6 error message? A: Do the following:
  • The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
  • Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
  • The needle could be bent. Replace the needle making sure the flat side is facing the back.
Brother sewing machine nx250 error message E6
Search for:
Make Model error E6
https://www.google.com/search?q=Brother+sewing+machine+error+E6&ie=utf-8&oe=utf-8
3answers
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
1helpful
Brother sewing machine screen displays E6
E6 is an error code. You didn't state the model number, but if you look in your instruction manual, it will list the error codes. If you don't have a manual, go to Brother.com and you can get the answer.
1helpful
E6 and F5 error message
Are you using the right size needle? Try using an 80. Also try taking it to a service center. To find one near you go here: http://www.brother-usa.com/service/
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
