Question about Nokia 3250 Cellular Phone
Stays in offline mode,even after reinserting sim
It doesn't ask if you would like to go out of offline mode
  • 4 more comments
  • Asunten Apr 04, 2008
    My Nokia 3250 is in "offline" mode, I cannot receive or make calls. When I try to set it to active mode it asks for the SimCard to be inserted while the Card is already in. It cannot recognize the card. Everything else on the phone works fine.
    I have done reformat/reset of the phone, but that did not solve the problem.
    Your help will be much appreciated.
  • Anonymous Jun 16, 2008
    OFFLIN PROFILE
  • ryan_roy_00 Aug 10, 2008
    offline mode showing in my phone 3250 plz hlp me
  • bernhard1940 Oct 03, 2008
    Hi, I have the same problem, also reformatted and tried everything else but it will not read the sim card at all. When switching it on, it goes strait through to the menu desplay, not asking for the pin code nor sim card. How much could a repair cost? Will it be worth it since the phone is quite old?
  • Anonymous Oct 19, 2008
    ADD THE SIM IN MOBIL MOBIL ASK SIM CARD IS NO VALID
  • gujjarmoiz Nov 17, 2008
    my nokia 3250 is in offline mode pl give me any solution. my email is gujjar_rockers@hotmail.com
It's due to sim IC failure u need to replace the sim IC give it to some nokia center the will do it
Posted on Jul 03, 2008
Upgrade phone version.
Posted on Apr 11, 2008
  • 490 Answers
Contact nokia care for card slot issue if doesnt works after replacement of sim as well or after replacement of h set as well good luck
Posted on Nov 10, 2007
My nokia c5 is in offline mode.icannot teceived text and calls.how can i change my mode to online
Make sure your phone is not in Airplane / Flight mode. Go to Settings > Profile. Select Normal.
If your phone still stays in offline mode, it is possible there is a problem with your SIM card. Turn off your phone; remove the SIM card; reinsert the SIM card; turn on the phone.
If the problem still persists visit your mobile phone store.
Feb 04, 2015 | Nokia C5 Cell Phone
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
Jul 08, 2012 | Nokia E Series E7-00 Touch Smartphone-...
How to change a n70 to online mode?
IF YOUR N70 IS SHOWING OFFLINE MODE PROBABLY BECAUSE IT DOES NOT READ YOUR SIM CARD OR YOU SELECT YES AT STARTUP. REMOVE YOUR BATTERY AND BRING OUT THE SIM, REINSERT PROPERLY AND STARTUP YOUR PHONE, THERE SHOULD BE A MESSAGE ON STARTUP " DO YOU WANT TO STARTUP PHONE IN OFFLINE MODE?" PRESS NO, (LEFT UPPER KEY) PHONE SHOULD STARUP ONLINE OTHERWISE YOUR SIM CARD IS NOT BEEN READ.
Nov 13, 2011 | Nokia N70 Cellular Phone
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
Mu nokia n73 is in offline mode even with my sim card inside the phone
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
Mar 05, 2011 | Cell Phones
How to make nokia off to online mode
just go to profile and select general, it will automatically put your device back to online
Jan 09, 2011 | Nokia E71 Smartphone
My nokia e72 still stay in offline mode .....how to change it..
offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Dec 19, 2010 | Nokia N72 Cellular Phone
Nokia n73 remain offline even inseting sim
turn off handset then take battery out then take sim card out then reinsert sim and battery then turn on the handset, it will prompt you saying somthing like this "Continue to use offline mode?" it will say "yes" and "no" in both corners you need to press "no" then wait for the phone to fully become functional and you should get your operator working!
Oct 04, 2008 | Nokia N73 Cellular Phone
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
My Nokia 3250 is in offline mode(Profile) and refuses to change back to a normal mode.
reinsert sim of ur fone and it will ask there continue in offline mode?select NO there and choose another profile....
Oct 09, 2007 | Nokia 3250 Cellular Phone
Nokia 3250 Cellular Phone Logo
221 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
