Computers & Internet Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Advice for buying a new power supply compatible with my videocard
MY SYS CONFIG IS
intel core2duo e7400 2.8ghz
2gb 800 mhz ddr2 ram
asus p5kpl-cm motherboard
segate 7200 rpm 80gb harddisk
creative sblive souncard with inspire 5200 5.1 speakers
sony dvd writer and samsung 52x cd writer
dell fp1909 ''19'' monitor
pinnacle internal tv tuner card
APC 650VA UPS
thinking of purchasing ATI Radeon hd 3850 graphics card whichprescribes a min 450w or greater power supply. i want to buy a newpower supplyshould i go for a 450w ormore.which good brand and model can i go for.i am thinking of Corsair VX 450W.what's your opinion.
Anonymous
Level 3:
  • Master 3,600 Answers
  • Posted on Jun 05, 2009
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1576387
Points
11774
Get a 600 watt they are better and will handle all that you need the price from a 450 W to 600W is not much I run 7 dvd's a ATI Video capture card with a 64 bit AMD processors 1 80 gig Hd 2 Sata Drives 120 gig and sound blaster audio card and more and the 600 watt does fine The Corsair is ok Where to you think your going to get it at on line? or at a store? You can buy them at
tiger direct.com or Fry's.com The 600 watt ATI power supply will have 6 standard HD connecotors and I use three Y's for more and never had any problem with mine.
1helpful
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
My PC config is 2GB RAM Intel core2duo processor Intel DG31PR motherboard i want to buy graphics card most compatible in affordable range near about 4 thousand rupees please suggest me which...
It depends on the motherboard, which graphics card it supports or which not. Note down you motherboard's model no. and brand, visit a computer shop. You'll find very good graphics card for Rs.4000/-. For 1gb graphics card with 1 vga, 1 dvi and 1 hdmi, it'll cost around Rs. 2500 to Rs. 2800.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
3answers
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
3answers
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
[can i use 2gb ram 800 mhz in intel d102ggct
Yes you can use 2 GIG of 800 mhz RAM on this motherboard since that is the max support of it.
1helpful
Does intel desktop board d945gccr support DDR2 Ram 667 or 800 MHz
intel d945gccr supports ddr2 400 mhz & 533 mhz it maximum support ram is 2gb
WHAT KIND OF PROCESSOR COMPATIBLE TO FOXCONN P4M800MO1
you can enter in your Mb any type of intel processors ranging max speed bus 800 mhz , for example you can enter intel pentium 4 hyperthreading 3.00 ghz , 800 mhz front side bus 1 mb cache, number 530, 530 j or better than him.
1helpful
Do i have to face any heating problems with the mentioned config?
If you are NOT going to overclock the CPU and memory, it should work easy.
New C2D processors are quite cool.
Also you shoult pay attention to a good Power supply, and maybe enough big case with place for front and rear extra fans,
If you face heating problems later, you may put those two fans.
Regards.
I have 810 bu mother board
your board is compatible with pentium 3 processors through the "coppermine" revision, the pentium 3 "tulatin is not supported" here is a list from wikipedia of the "coppermine" processors supported by your board.:
Coppermine
  • 100 MHz FSB: 500, 550, 600, 650, 700, 750, 800, 850, 900, 1000, 1100 MHz (E-Models)
  • 133 MHz FSB: 533, 600, 667, 733, 800, 866, 933, 1000, 1133 MHz (EB-Models)
Coppermine-T (the only coppermines with an attached heatsink)
  • 133 MHz FSB: 800, 866, 933, 1000, 1133 MHz
The Tulatin core is NOT compatible with intel 810 boards, and they can be easily confused with the coppermine-t's because they also have attached heatsinks.
Grand Canyon Tech
Grand Canyon Tech
