Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Samsung LE32R41BD problem
my samsung LCD tv has an intermitant fault. occasionally the screen goes black for a few seconds.Can you solve it?
  • johnque Dec 01, 2007
    However when I connect it to computer the problem doesn't occur at all. So do you think it is back light problem or board problem?
    Waiting for reply.
  • 1,139 Answers
Hello johnque,
I would suspect that this might be a back-light problem. However this may also be a screen issue. There are many things this could be and it will require that a person troubleshoots the unit to actually find out what is wrong. I know you wanted a quick fix for this but this unit has to be diagnosed, so to that end, if you have a background in electronics these are the tools you will need to complete this task;
1) A schematic diagram of the TV
2) A Multimeter
3) An Universal Video Analyzer or Computer Monitor Analyzer
4) An Isolation Transformer
With the tools and knowledge of electronics this becomes an easy problem to solve. Now if you do not have knowledge of electronics I would suggest that you take your set to a qualified TV repair shop for servicing.
Thank you,
Posted on Oct 25, 2007
  • Henry McKelvey
    Henry McKelvey Dec 01, 2007
    Since you say this the problem could be on the board where the TV inserts signal, vs the connections where the Computer inserts signal you will still need a schematic and equipment to trace the signal from both inputs.
    Let me know how this turns out.
How do I fix an occasional black screen on a Samsung LN46B630?
Sounds like T'Con board fault. For some models of Samsung LCD TVs, this part is built in the panel, means non-replaceable. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Aug 20, 2015 | Samsung LN46B630 LCD TV
32' Samsung LCD Tv vertical bars on screen / sound
your lcd panel micron tube has already wron out. time to replace the panel
Apr 25, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I have a samsung LN26A330j1D lcd tv ,the screen comes on black then fades to all white from the center of the bottom.does anyone know what part would be out causing this ?
There are a number of causes. First The T-Con bd has gone bad. Second the Main bd is bad and third the LCD Panel is bad. Have a trained Samsung tech troubleshoot the problem
Jul 11, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LCD flat screen goes black. Turn tv off and back on it's fine for about 15 minutes and keeps doing it.
Sounds like your power board is failing. contact samsung tech support and describe your problem. some parts on samsung have lifetime warranties and the service call is free.
Apr 09, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung lcd tv
I'm having the same issue. I'll be watching the television an all the sudden the screen goes black/turns off. I turn it off and back on again and picture comes back on. It doesnt seem to have any consistency..
May 26, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung le32r black screen
Your problem sounds like inverter has failed.
To prove this you need to remove the back from your tv set.
Then switch it on and look carefully through the small holes on the metal shielding that is directly over back of screen you are looking for bright white light.
If you cant see it easily try doing again but in A dark room.
If you can see white light through the holes in metal shielding the inverter is working & fault is else where.
If no light can be seen problem is with inverter you will need to remove the inverter pcb & check the transformers with ohm meter to see if one is open circuit. Allso look on same pcb for any smd circuit protectors that may be open circuit.
Jan 03, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung 32" LCD HD TV Problem
I would first try replacing the cable if the problem remains the same it will almost certainly be a bad connection on the socket or panel in the back of the TV.
Simple to solve if you have any soldering/TV repair experience.
If not take to the repair shop, it shouldn't cost a lot to put it right.
Dec 17, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Tv freezes, goes black, starts again
I had a similar problem, mine was a bad earth connection on the main (tv input) board. it earths through the screw mountings so check they are screwed in nice and tight, probably best to remove and then refit it.
Dec 11, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung lcd tv
that is deafinatly a fault. take it back to the store asap if you can. what the tv needs to be fixed is first replace the main and power board and if problem persist the lcd panel will need to be replaced.
Nov 04, 2007 | Televison & Video
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
183 people viewed this question
Jerry Greenberg
Jerry Greenberg
